Old 04-01-2013, 01:25 PM   #1
AC Yate
My Ride: BMW E46
Do leaks in vanos like look like OFHG leaks?
So I redid the OFHG this weekend after I saw oil puddling at the honeycomb area. I read that this is a common sign of a OFHG leak. I didn't replace the vanos line because I read that the leaks are usually slow and are typically buildup of oil residue rather than oil pools. Just in case i observe more leaking, What are the chances that the vanos line is actually leaking (like in the crimp area) and pooling in the honeycomb area?
AC Yate is offline   Reply With Quote
Old 04-01-2013, 02:14 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Did you replace the crush washers after removing the line? Reusing the old crush washers might result in a faster leak
Old 04-01-2013, 02:24 PM   #3
AC Yate
My Ride: BMW E46
Yes I replaced the washers.
