Old 04-02-2013, 01:44 PM   #1
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
Long time no see guys. Engine rebuild time
So looks like I'll be buying another 3.0L M54 engine but this time I'm going to bore it out to 3.2L ( at least that's the plan ) I'm also going to put in metal head gasket and low compression pistons so I'm able to put a 10-12psi pulley on my supercharger.
Now my question is for you guys is. What pistons/rebuild kits do you all recommend?. I've seen quite a few but I don't know truly which ones are proven to last or be good for an application like this. I also would like some recommendations of some good cams and rods/bearings the whole shabang.
I forgot to mention I will be doing all the work myself with the help of E46Mango on the forums most likely and my other friend who's not on any forums. It'll be a long and interesting project.
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 04-02-2013, 02:01 PM   #2
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Personally I'd find something better than the aluminum block if you're going to boost.
braymond141 is offline   Reply With Quote
Old 04-02-2013, 02:29 PM   #3
Cruzader
My Ride: Alpinweiß facelift
m54b22 swap
Cruzader is offline   Reply With Quote
Old 04-02-2013, 03:05 PM   #4
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Ouch did the motor give out ?
It's been awhile since you upgraded to a custom intercooler on your vf kit.
S54 would be sweet too
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 04-02-2013, 03:38 PM   #5
MalibuMafiaV
Originally Posted by Cruzader View Post
m54b22 swap
Humm I already have a M54 3.0L though. You just made me think about maybe the 540i v8 engine....
Nope engine didn't give out yet. But it may have a head gasket leak so I don't really feel like going through all of that without doing a serious rebuild. Going to do a combustion leak test to see if there's any stuff in the coolant first this week.
TheMalibuMafia.com
Instagram
Old 04-02-2013, 10:38 PM   #6
TrippinBimmer
My Ride: Just Fast!
I guess your motor been PING alot to have a gasket let go or over-heated.
CP piston, Eagle Rods, Vaio Oil Pump, ATI Damper, Calico Coated Main and Rod Bearings, MLS Headgasket, Wurth timeserts, and Raceware Hardware. You will have about 3-3.5k on the bottom end. Now, lets talk about the top end. Vac Titanium Valve Seats, Springs and 1+mm intake and exhaust valves, and port and polish job. That will be about 5-6k on the top end. There is more but I double u wanna go that crazy do u? Also 3.2L lol
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-03-2013, 01:58 AM   #7
paraklas
My Ride: ESS TS2 320ci
m54b22 swap
why this engine?
Old 04-03-2013, 07:50 AM   #8
SweTurbo
Big Pimpin'
My Ride: 323i -98
Boring the M54 to 87mm(3197cc) isn't an option iirc
There's a 3.2L crank but it's $$$
Old 04-03-2013, 08:58 AM   #9
sedanpowersc
My Ride: 330i 5 speed
There's a German company that sells stroked 3.3l m54s for like 12k
| BB Gen 3 Headers | Cosmos Racing V2 CAI | Muffler Delete | RE Underdrive Pulleys |
| 3.46 Diff | Tein S-Tech | Bilstein Sports | Hawk HPS | ASA AR1 | 35% Tint |
sedanpowersc is offline   Reply With Quote
Old 04-03-2013, 09:29 AM   #10
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
You can get the S85 for like 10K now.
AMG-ETR is offline   Reply With Quote
Old 04-03-2013, 11:41 AM   #11
lab rat
My Ride: '02 330iT
I'm going through the same decision right now. Got a spare M54B25 and thinking about bulding it for lower compression with b30 crank.
I don't think I'm gonna do it. It's just too much money.
At 330whp and good low end (twinscrew 8PSI) I don't have to worry about the rest of the drivetrain too much.
If I put $4k into the bottom end I would still need:
tune - 0-$1000, depending on ESS
clutch - $1000
FI cam - $1400
rear axle shafts - this would likely require rear trailing arms, brakes
new rear tires every two months
Because sleeper
Old 04-03-2013, 06:47 PM   #12
MalibuMafiaV
And with all that said. I'll probably just put another 3.0L and just put new piston rings on and and a metal head gasket. Everything else is far to expensive sounding. I thought it might be like $1500-2000 if I did everything myself... f u expensive parts. Regardless I shall take tons of pictures as usual when I do a job like this and post them up for you guys. But I'm just not entirely sure when I'll get started on the project. But when I do start I will make a new thread for sure.
TheMalibuMafia.com
Instagram
Old 04-03-2013, 06:59 PM   #13
TrippinBimmer
My Ride: Just Fast!
Won't u be a square one? Blow another HeadGasket again?
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-04-2013, 01:02 PM   #14
MalibuMafiaV
Blow another head gasket in like 100k miles I'm fine with that.
TheMalibuMafia.com
Instagram
Old 04-04-2013, 06:51 PM   #15
TrippinBimmer
My Ride: Just Fast!
You been boosted for 100k already?
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-04-2013, 06:52 PM   #16
MalibuMafiaV
Na. I'd say 60k. But motot was replaced before then and got to around 100k before this has happened 98k to be exact.
TheMalibuMafia.com
Instagram
Old 04-04-2013, 06:56 PM   #17
TrippinBimmer
My Ride: Just Fast!
still Anyways, best of luck bro
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-04-2013, 07:37 PM   #18
dirty vert
My Ride: 2001 330ci
What about an LS7 conversion? If you want power.. It would be more time consuming,but one hell of a ride afterwards.
If there is an option, how about having the 3.0 bored, then sleeved with steel sleeves, then you could have those bored if needed. (kinda old school)
dirty vert is offline   Reply With Quote
Old 04-05-2013, 05:27 PM   #19
MalibuMafiaV
got me thinking now.... But at the moment it looks like I'll just be rebuilding another 3.0 and just putting metal head gasket in and new piston rings.
TheMalibuMafia.com
Instagram
Old 04-05-2013, 08:00 PM   #20
dirty vert
My Ride: 2001 330ci
If I had to do another engine, I would seriously look at the swap. Just something to think about.
I knew an old man once that had a 55chevy belair, he had the block bored then sleeved it with steel and then bored the steel sleeves. I'm sure ot would cost a bit, but it can be done.
I'd also probably put 325 emblems on it too...just a little sleeper.
