Car won't move when cold. ((UPDATED)) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-02-2013, 02:24 PM   #1
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
2004 325i, automatic transmission.
My car won't move when i start my car. The RPMs went past the 2000 but didnt move. After letting it warm up for 5 minutes it started moving but slowly slowly. And got better after few minutes sometimes. Also, I feel the jerk sometimes when its shifting.
The transmission was replaced about 3 years ago with a used tranny which had about 70k miles on it and i only put another 20k miles on it.
Can anyone please help me with this. Thank you
rizwan1377 is offline   Reply With Quote
Old 04-02-2013, 02:25 PM   #2
Adionik
My Ride: Bavarian Panzer
Sounds like your tranny is jacked. Maybe try changing fluid
Originally Posted by Brinkley View Post
I tried to start my car without my undertray today. It exploded in a ball of fire. I put the tray back in, hoping that will fix the issue.
Adionik is offline   Reply With Quote
Old 04-02-2013, 02:26 PM   #3
Dave1027
My Ride: '06 IR zhp coupe
Could simply be extremely low on tranny fluid.
Old 04-02-2013, 02:32 PM   #4
Slow_335i
My Ride: 2008 E92 335i
It's frozen, let it thaw overnight...
Slow_335i is offline   Reply With Quote
Old 04-02-2013, 02:46 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Seach my user name and "transmission" you will likely find more info than you would prefer to read.
Make sure fluid is not low first, but likely internal hydraulic leakage when cold.
Need to carefully nurse car and possibly manual shift until trans fluid warms up a bit.
Also check the 3rd link below in my signature for engine coolant temp issues and note the auto trans has a specific thermostat for it in the bottom of the expansion tank as well.
But engine temp and trans thermostat will not likely do much to improve matters.
Old 04-03-2013, 10:03 AM   #6
rizwan1377
Thank You guys.
Even if it is low on fluid it means that there is a leak. I am probably gonna put it it on a lift and check everything out. My MAF is also not good becasue the engine runs the same if i disconnect the MAF.
Old 04-03-2013, 10:29 AM   #7
adaseb
My Ride: 2002 BMW 320i
Its normal if its very cold where you live.
Mine has been doing this since new pretty much.
adaseb is offline   Reply With Quote
Old 04-03-2013, 10:34 AM   #8
Jat007
My Ride: 99' 323i
Definitely related to your tranny. As other members had mentioned to you that either the fluid is low or old. I believe the fluid is old. I had the same symptom on my 99' e46, but mine wasn't taking 5 mins, only 2-3 minutes or so. Once I had the tranny fluid flushed entirely and now the transmission shift like new regardless of the temperature.
I had it done at a trusted shop with 12 quarts of tranny fluid. I wanted to make sure that all of the fluid are drained... The labor was only $100 and that was the best investment so far on my e46
Jat007 is offline   Reply With Quote
Old 04-05-2013, 09:00 PM   #9
rizwan1377
yes, it is low on fluid. I put it on lift & everything was wet. and the fluid was dripping from the transmission. I found out that it is the transmission seal. I hope i can get the parts on sunday so we can take out the tranny.
Old 04-05-2013, 09:01 PM   #10
rizwan1377
No, it is normal. the weather is getting better now, but it didn't had any problems before.
Old 04-05-2013, 09:03 PM   #11
rizwan1377
The fluid was filled with new OEM transmission fluid when i replaced it the transmission.
Old 04-14-2013, 01:34 PM   #12
rizwan1377
So here is a little update:
The transmission seal is broken, & it is hard as a metal. Finally got the new seal from the dealer and should be done within 2 days.
Old 04-14-2013, 02:21 PM   #13
jfoj
I imagine more than your front torque converter seal is hard.
You likely should reseal the clutch packs and install new clutches since you have the trans out of the car??
Old 04-14-2013, 06:51 PM   #14
rizwan1377
Its almost finished now. Just need to put the exhaust back in the morning, will see what happens.
Old 04-14-2013, 07:13 PM   #15
lszlszx
My Ride: 1.8T, XC70
Congrats for finding the problem! Are you sure that tranny only had 70K when they put it on?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-14-2013, 08:55 PM   #16
rizwan1377
It should have the correct mileage, bought it from LKQ.
Sent from my ADR6425LVW using Bimmer App
Old 04-15-2013, 07:45 PM   #17
rizwan1377
Okay, my car is alive again. The new seal solved the problem & it shifts/drives perfect.
Also, found out that my oil filter housing gasket was bad so that was also replaced.
Old 04-15-2013, 08:06 PM   #18
jfoj
Glad you got it sorted.
Was this a DIY?
Was the seal just hard and brittle and crack?
I think this is about the 3rd or 4th one like this in the past few months.
Hopefully this is not a new failure mode that many of use are going to be seeing?
Old 04-15-2013, 08:33 PM   #19
lszlszx
My Ride: 1.8T, XC70
What is the function of that seal?
Old 04-15-2013, 09:31 PM   #20
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
So your transmission is a ZF Automatic.
That is the converter seal, that when working prevents fluid from leaking around the torque converter. There is fluid that flows out into the torque converter and then flows back into the transmission.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
