///M3 Forum
Old 04-02-2013, 11:29 PM   #1
KSK
My Ride: //M
Engine codes indicating VANOS failure?
Hey guys
Long time lurker first time poster. Hoping I can get some insight on this here
I just got the trouble codes read on my 02 m3 and got the following:
43 - Activation, inlet VANOS, bank1, advance valve
07 - Signal, camshaft sensor, inlet, bank 1
B8 - Function, inlet VANOS, bank 1
16 - Activation, exhaust VANOS, bank 1, advance valve
B9 - Function, exhaust VANOS, bank 1
Do these sound like a typical VANOS system failure that will require the unit to be replaced or is further diagnosis recommended? I'm thinking of doing the repair myself
KSK is offline   Reply With Quote
Old 04-03-2013, 01:43 AM   #2
sakumaxp
My Ride: 02 M3 convertible
You can't really "repair" a vanos you have to buy a new refurb or brand new one, when my vanos needed to be replaced I went with dr.vanos, look them up and they give you 400 dollars back if you give them your old vanos, good luck with everything
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 04-03-2013, 08:09 AM   #3
karl hungus
My Ride: 2004 M3
First time getting these codes?
Do you have any other symptoms (rough idle, sluggish performance, rattling sounds, ect?)
Reset the fault codes and allow the engine to idle. If the fault codes are generated in a few minutes, then the vanos malfunction is likely to be one of two things: loose intake sprocket mounting bolts OR vanos malfunction caused by broken vanos oil pump exhaust sprocket hub driver tab(s). These are two common reasons Vanos codes are generated..
If the car does not generate the codes within a few minutes, then it's likely to be intermittent solenoid failure which is a much easier and cheaper thing to fix.
I struggled with intermittent vanos related issues for months and months before I realized my issue was with a faulty solenoid. Simply going to the dealer and replacing the solenoid will result in the same codes eventually because of the faulty OEM design. So I refer you to Beisan Systems who solved all my vanos troubles with their remanufactured solenoid pack.
I stopped taking my car to the dealer for vanos diagnosis since they refuse to acknowledge the OEM faulty solenoid and faulty cam bolts. Try those things out I told you and let me know what you come up with...
2004 Silver Grey M3
karl hungus is offline   Reply With Quote
Old 04-03-2013, 11:29 AM   #4
choxor
My Ride: JDM
Yes, it sounds like the solenoid pack. The problem does not have to be intermittent. Mine was not.
It could still be the tabs, though.
Old 04-05-2013, 12:38 AM   #5
KSK
My Ride: //M
Have all those symptoms, rough idle (not too bad but a bit rough) performance loss in low rpm and I was told by a friend driving in a car beside me that the engine sounded weird and "off"
Not too sure how long those codes have been, I changed the exhasut cam position sensor a while back since I was told by a mechanic I had that code when I bought the car, but hadn't bothered resetting the computer since, it's been almost 8 months. I just reset it after reading the above codes, going to change the intake cam position sensor before turning it on (since I already have it) then let it idle and monitor the codes again as you mentioned above
Worthy to mention the previous owner had changed the Vanos with a Dr Vanos unit approx 2 years ago, which also apparently came with a new solenoid, so I'm a bit surprised to see these codes, and that's why I decided to change the sensor first, even though it's most likely not the cause
Thanks for the Besian referral, will definitely give them a try if it narrows down to be the solenoid
Old 04-05-2013, 12:47 AM   #6
KSK
My Ride: //M
IS there a general consensus on here regarding reliability of these Dr Vanos units? As mentioned above both the vanos and the solenoid had been replaced by the previous owner with Dr Vanos replacements approx 2 years back
Old 04-10-2013, 03:28 PM   #7
karl hungus
My Ride: 2004 M3
I don't trust the Dr.Vanos solenoid replacement since it is a direct factory replacement solenoid. Which means, it is susceptible to failure in the same way. The beisian systems solenoid is literally remanufactured to correct the faulty solder joints and sealing plate O rings.
2004 Silver Grey M3
Old 05-28-2013, 07:52 PM   #8
XKR
My Ride: 2001 M3 Convertible
do you have any misfires? I'm having a similar problem with the codes saying that it's vanos but I think it's the o2 sensor. my car runs fine when it's moving but when it idles, it misfires and throws on a check engine light and when i turn it off and back on, it goes away
XKR is offline   Reply With Quote
Old 05-28-2013, 08:14 PM   #9
vlcmstnsct
My Ride: 2002 E46 330i
Re: Engine codes indicating VANOS failure?
You can rebuild your vanos like myself and many many others have done.
www.beisansystems.com
Sent from my SCH-I535
Regards,
Aaron
2002 330i 5spd
VIR Oktoberfast 2013
vlcmstnsct is offline   Reply With Quote
Old 05-28-2013, 08:32 PM   #10
XKR
but I don't thinks it's vanos lol. they had the headers out so maybe they plugged the o2 sensors into the wrong plugs I hope that's the case
~SGT catless headers|Full BW 3.5" Resonated Race Exhaust w/ diffuser | Epic Motorsports Race Tune | BAC Filter | BW Intake Elbow
~Tein S-Tech Lowering Springs | Sebion CF hood | CF Kidneys | ‹mnitiza Predator Orion V4
Old 05-29-2013, 01:13 PM   #11
karl hungus
My Ride: 2004 M3
It's possible that the O2 harness was reversed during the header install. What exactly are your codes?
2004 Silver Grey M3
Old 05-29-2013, 08:03 PM   #12
XKR
uhh I don't know off the top of my head but I could tell you what is wrong with it. So basically if I let it idle, it starts to (cylinders 3-6) misfire and the check engine light comes on but if I turn the car off real fas and restart it, all is good and the light goes off. I hope it's just the o2 senors reversed
Old 06-01-2013, 02:03 AM   #13
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
I had the same problem when I put header son... I had reversed the o2sensors. Looking the web and there r some pics that help identify them. Soon as I made the change the car ran great.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-01-2013, 06:06 PM   #14
XKR
apperantly mine was a ground problem. and the coilpack needed updates because of the brands. something about how bremi coils were bad or I think I was running Bosch coils. not sure but the problem got solved
