General Off-Topic
Thread Tools Search this Thread Rating: Thread Rating: 45 votes, 5.00 average.
Old 04-09-2013, 12:01 AM   #561
HaloArchive
My Ride: My Office Chair
Originally Posted by Stiggles View Post
Reaper download mirror seems to be down. Is there any way you can supply this to us?
Originally Posted by k2pilot View Post
I've been trying to find some info on how to config reaper to work with multiple different GPU's, do to the nature of my home computer (hackintoshed) I can't boot in to windows with just my 7950's installed, so I have to keep my 5850 in there, trying that with the device #'s in place still causes a complete OS crash, probably because there's no way to know what reaper is seeing as device X.
So halo, know of any way to configure reaper for different cards at the same time? Or at least figure out how to know which card is which so I can disable my 5850?
try doing the two same video cards in one instance and the oddball in a different one.
HaloArchive is offline   Reply With Quote
Old 04-09-2013, 12:25 AM   #562
Shaban
My Ride: 2005 CBR600
Originally Posted by HaloArchive View Post
Easy. Your computer should be able to support all GPU's in reaper.
#reaper.conf
kernel reaper.cl
save_binaries no
enable_graceful_shutdown yes
long_polling yes
platform 0
device 0
device 1
device 2
mine litecoin
Didn't know it was that easy, I thought I had to set a different intensity for each one and add more stuff to the reaper.conf file. What does platform 0 do? I don't have that in my file atm, only device 0
- Alex
Shaban is offline   Reply With Quote
Old 04-09-2013, 12:31 AM   #563
k2pilot
My Ride: Z4MC & F56 JCW
Ah so I assume reaper doesn't have any ability to run multiple different cards, unlike cgminer.
"I love deadlines. I love the whooshing noise they make as they go past." Douglas Adams
k2pilot is offline   Reply With Quote
Old 04-09-2013, 01:14 AM   #564
Stankia
My Ride: F80 M3
What the hell, they increased the difficulty again?
Ne Mi takie, Zhizn' takaya
Stankia is offline   Reply With Quote
Old 04-09-2013, 03:12 AM   #565
k33psp00lin
My Ride: 03 330i
Yeah what are your thoughts on difficulty increase?
k33psp00lin is offline   Reply With Quote
Old 04-09-2013, 07:38 AM   #566
Guest021715
Account closed.
I was running Reaper and Scryptminer overnight.
In the morning Reaper had long since been closed. What could be causing this?
Old 04-09-2013, 10:02 AM   #567
limpiabota809
My Ride: 330 XI
Will read later
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 04-09-2013, 10:28 AM   #568
Shaban
Anyone having a problem with notroll? I haven't withdrawn at all and I've lost 2 LTC?
Your Balance: 6.50881558 LTC
Total Earned: 8.67482643 LTC
- Alex
Old 04-09-2013, 10:41 AM   #569
Guest021715
Account closed.
Did you set up auto payout?
Old 04-09-2013, 10:43 AM   #570
HaloArchive
Nope but the trade off is increased stability.
Yep.
Sucks but its caused by a ton of new miners. The past week the network has seen a 1 GH/s increase. Back when I got into mining LTC, difficulty was around 50
Did reaper quit or did your computer restart?
The situation will be rectified most likely. The owner of notroll is in the hospital for an appendicitis.
Old 04-09-2013, 10:46 AM   #571
Guest021715
Account closed.
Reaper was just not running when I woke up.
GPU fans were set at 100%, with temp at 78C max. (before bed)
Old 04-09-2013, 10:56 AM   #572
Shaban
^ Probably hit max temp and cut off.
Found out that notroll.in was paying double on accident over the last 14hours and they corrected it, so everyone lost the extra LTC.
So difficulty went up, PPS went down, and problems with the pool?
I also keep trying to withdraw to BTC-e and I keep getting "transaction failed(incorrect address?)
- Alex
Old 04-09-2013, 11:00 AM   #573
turbotalon1g
My Ride: '02 330i
I'm thinking that I might try this, but I have to run it by the boss first.
I'll try and get that setup you put in the OP, but I'd like to do 3 cards and then find a milk crate case to put it in. Our power charge is .113/kWh
turbotalon1g is offline   Reply With Quote
Old 04-09-2013, 11:00 AM   #574
HaloArchive
Yeah, watch reaper and temps for 15 min from startup. if it climbs into 90's, you need to do something lol.
Yep, thats why I am part of many pools!
Old 04-09-2013, 11:01 AM   #575
Shaban
I'm thinking of switching from notroll.in tonight, any pool you suggest? I hated litecoinpool.org and notroll.in has a lot of problems
- Alex
Old 04-09-2013, 11:03 AM   #576
HaloArchive
My tops are notroll, litecoinpool and burnside.
Old 04-09-2013, 11:06 AM   #577
Guest021715
Account closed.
It was a solid 77-78C for 1 hour before going to bed, hence my confusion
No BSOD, no error messages of any kind.
Old 04-09-2013, 11:10 AM   #578
Shaban
You have your max temp set at 78*, and you're saying it was around 77-78* before you slept, so yes it could have reached max temp. Change your max temp to 84*C. Or try to keep it cooler, I have my PC next to an open window + 13 fans running and it's around 74*C
- Alex
Old 04-09-2013, 11:19 AM   #579
Jesse M
My Ride: 05' ZHP
CGMiner is glitchy. Use reaper. You can overclock your card to 1025 core, 1480 mem at 1100 mV. (1.1v)
speaking of OC'ing, I was messing around with my new EVGA 660Ti, got a stable clock at 1244mhz core, and 3.4GHZ mem @ around 1.125Vcore. Temps never got above 62C on the card.
Anything over 1300mhz on the card was causing a glitch while playing 2033, it would just crash, so I backed off a bit. I'm super impressed with it man. 1080p resolution, everything cranked to ultra. Lowest fps I got was like 30 but it was for a few seconds. Too bad I picked this out before this BTC mining. lol
Now I want to mess with the 3570k
Jesse M is offline   Reply With Quote
Old 04-09-2013, 11:23 AM   #580
Guest021715
Account closed.
I meant, the maximum temperature I observed was 78.
There isn't anything setup to turn it off, except its auto-shutdown safety at 105.
Edit: EVGA specs say max reccomended is 85.. I suppose its possible it reached that after a few hours (but doubt it)
Rate This Thread
