Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-04-2013, 09:46 AM   #1
Green_Shine
My Ride: Back seat riding
Power protection for new TV/theater install
I'm unsure of the best way to approach this.
I'm finishing my basement and I will have a built-in entertainment center. My plasma will be mounted to a wall within it. A few feet below will be the receiver, PS3 and other devices hidden behind a built-in in door.
What is the best way to get power from the TV to the lower level of my built-in that would be protected? I'm not sure I would feel comfortable using a receptacle surge protector. Ideally I will have all my devices and coaxial connected to Panamax or APC unit with UPS or some line conditioning for brown outs.
DO you think a wall-plate with an opening will work? I'm going to use one to run the HDMI down as I hate to limit myself with HMDI wall plates.
EDIT- What do you think about this:
http://www.monoprice.com/products/pr...=2#description
Green_Shine is offline   Reply With Quote
Old 04-04-2013, 05:05 PM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Panamax has in wall kits specifically for this...
You put an input receptacle at one end and an output at the other and romex between them then plug it in to the same power regulator/surge component so they all share the same power.
http://www.panamax.com/Products/In-W...WERKIT-PRO.php
http://www.panamax.com/Products/In-Wall/MIW-XT.php
PS - it is unwise and against code to run power wires through the wall. Use must use ROMEX and terminate in an electrical box.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 04-05-2013, 01:49 PM   #3
Green_Shine
Perfect. That looks like better quality than Monoprice. I'll buy that thanks.
Old 04-05-2013, 03:47 PM   #4
GlockMan
GlockMan's Avatar
Did not even look at the Monoprice one, but I have used the Panamax one for years. They probably invented it.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-07-2013, 12:14 AM   #5
westom
My Ride: lexus
Any protection that works on the power cord is already inside the TV. Read its specification numbers. That Panamax only claims to protect from a type of surge that typically causes no damage.
Concern is another and different transient that can overwhelm a Panamax and protection already inside the TV. In every facility that cannot have damage, that solution is always located at the service entrance. Where wires enter the building. Then everything - not just a TV - is also protected. That least expensive solution is also the only solution used for protection from another and typically destructive surge.
Any protection mounted in a wall receptacle typically exists inside appliances. Another and different anomaly can overwhelm that already existing protection.
westom is offline   Reply With Quote
Old 04-07-2013, 08:19 AM   #6
GlockMan
GlockMan's Avatar
^ it is not about surge protection, that is done at the power conditioner/surge protector.
This is just a way to get all your power plugged in at the same power conditioner/surge protector when the equipment is located in different areas.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
