Oil in exhaust, plz help a noob! - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-05-2013, 03:40 PM   #21
Mdm330
My Ride: 2006 ZHP
I had only been topping it off with the castrol, I have no idea what oil the previous owner was running, so maybe I'll try another oil change with what y'all have recommended, either the castrol or bmw 0-30?
I didn't realize you could watch the coolant temp in real time, so the first time I brought the display up the car was not running and had been sitting. Upon further investigation I found they if I brought up the coolant temp on the cluster and then start the car I watch the temp as I drive and stayed at the normal low-mid 90's
Mdm330 is offline   Reply With Quote
Old 04-05-2013, 06:19 PM   #22
Nateweav
My Ride: 2001 330Xi
Originally Posted by hacksawmark View Post
In your valve covers but not on the filler cap? Hmmm, still doesn't sound good. Any oil consumption issues; how often do you have to add a quart? Have you checked your coolant temps on the OBC? Also, what kind of driving do you do; lot of short trips? How often do you take it out on the freeway for 30 minutes or more?
It will use about a quart every 8 months. I don't think that's too bad for having 111,000 mi. Plus the oil lines on the front leak a little bit. I have to tell you when I first got it (1.5 yrs ago) I did the valve cover gasket and noticed just a touch of mayo. Since then the thermostat was stuck open for a few months. Just did the overhaul last weekend. When the t-stat was open I noticed more mayo. Since the rebuild It has gone back down now that she is running at normal temp, and I ran it a good distance to get a lot of heat and help it out. I drive 7 miles each way to work, but I always let it warm up for a few minutes to "jump start" the heat. I now have a new problem. Twice now it has poured a ton of white smoke out the tail pipe. Once before the coolant overhaul, once after. Oil isn't milky, never got hot, and no pressure in the coolant system. So, I don't believe its a head gasket.
Nateweav is offline   Reply With Quote
Old 04-05-2013, 07:27 PM   #23
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Not sure about the white smoke; sounds like coolant in the oil. But your daily drives of seven miles each way is not enough to get the engine to operating temps. Letting it warm up doesn't really help; just wastes gas. I suggest once a week taking it out on the freeway for 30 minutes at freeway speeds.
HacksawMark is offline   Reply With Quote
Old 04-05-2013, 07:32 PM   #24
Nateweav
My Ride: 2001 330Xi
I thought coolant in the combustion chamber too. But, when I smelled the smoke it kind of smelled gassy. Not like anti freeze or oil. I am beginning to hate this car... Shoulda bought the Lexus IS250 awd. Too bad they don't have the power or handling of my e46! Can you tell me how to access the coolant temp in the obc?
Old 04-05-2013, 08:01 PM   #25
jfoj
My Ride: 330CiC, M5, X5, E93
3rd link below in my signature.
Old 04-06-2013, 06:11 AM   #26
Nateweav
My Ride: 2001 330Xi
That would cool if my car had access to this. When I go through the options, it only gives me 1.0 thru 1.7. Am I doing it wrong?
Old 04-06-2013, 06:15 AM   #27
jfoj
Nate, you are doing something wrong.
Check YouTube, you will get it.
Old 04-06-2013, 11:33 AM   #28
Nateweav
My Ride: 2001 330Xi
Yep. Got it. Drove it for 25 mins on highway and the gauge bounced between 93 & 94. But it was 28 here this morning. So.... does that sound right?
Sent from my SGH-S959G using Bimmer App
