Old 04-05-2013, 07:49 AM   #1
BlaccDiamonds
My Ride: 04 330Ci + 02 4.6is
Exclamation Gas Pedal floored, car doesn't move???
Hi everyone, got a serious issue that I can't figure out.
I was helping a friend out yesterday putting his expansion tank and hoses back together on his 1999 328i...everything went well and we bleed it properly.
Now, onto the issue...when he goes to gas the pedal the car will not rev up or move at all??? Why is that? The only way the car moves if he selects 1st gear and let the transmission/engine slowly creep the car forward.
I had him try to rev the car in neutral and still nothing. I thought he was joking but when I saw his pedal to the floor then I realized..." this is f*#$ up?!?!"
LOL...but no joking...can you help me diagnose and figure out the problem? Cuz I don't have a clue.
Thanks in advance,
Benny
BlaccDiamonds is offline   Reply With Quote
Old 04-05-2013, 08:01 AM   #2
//Maxwelljuppercut
My Ride: e46
forgot to plug something back in?
//Maxwelljuppercut is offline   Reply With Quote
Old 04-05-2013, 08:07 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check your fuel pressure at the fuel rail. Maybe the fuel pump crapped out.
Check connection? MAF, throttle.
Any CEL?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is online now   Reply With Quote
Old 04-05-2013, 08:10 AM   #4
jfoj
My Ride: 330CiC, M5, X5
Unplug and reconnect the connector on the throttle body??
Disconnect the battery for 30 minutes and reconnect??
Old 04-05-2013, 09:28 AM   #5
BlaccDiamonds
Thanks everyone, I will stop by my friends after work. I feel he forgot to plug something back in also, but the strange thing is the car starts right up with no problems?? Only when he tries to gas it the car won't move!
Only light he says he has is the "service engine soon" light...nothing else.
Old 04-05-2013, 09:32 AM   #6
Tament
My Ride: 2001 330I
Get the code read, that may give a clue as to what is happening.
Tament is offline   Reply With Quote
Old 04-05-2013, 09:34 AM   #7
WDE46
My Ride: '13 128i, '04 330Ci
Definitely left something unplugged or accidentally unplugged something. If I am not mistaken, the 328 uses a cable controlled throttle body. Take off the intake and see if you can see the wire there moving the TB. Maybe it came off or broke.
Old 04-05-2013, 09:37 AM   #8
cvx5832
My Ride: 325Ci, 325Cic, C300
Car will still start without the throttle body. At idle, it's breathing through the ICV.
That said the 328 still has a mechanical linkage, but I agree with everyone to check the connections that may have been disturbed.
cvx5832 is offline   Reply With Quote
Old 04-05-2013, 09:54 AM   #9
BlaccDiamonds
This makes a lot of sense. Also, I thought the car had an electrical throttle...didn't know it was still mechanical, which makes even more sense. The car has been sitting around all winter outside also so could be broken cable or maybe just came loose.
Thanks again everyone!
Old 04-05-2013, 12:17 PM   #10
WDE46
The M52 uses a mecanical TB. M54 moved to electronic.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-05-2013, 12:55 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
Open the hood.
Have a helper step on the gas pedal -- engine off.
Look under the hood for stuff that moves, and stuff that does not move.
Reconnect what moves to what does not move.
Close hood.
Old 04-06-2013, 08:15 AM   #12
BlaccDiamonds
Fixed it! Turns out the throttle cable came loose.
So I carefully...without taking the throttle body off, replaced the cable and adjusted the tension on it. I guess after such a long time parked the cable just came loose... weird.
Thanks for all your help with this!
Old 04-06-2013, 11:08 AM   #13
lszlszx
My Ride: 1.8T, XC70
That is weird because the throttle valve needs to be turned in order to disconnect the cable, maybe someone worked on the car?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
