Old 04-05-2013, 08:11 AM   #1
auto feature
My Ride: E46 318i/E90 320i
Engine oil dipstick showing no readings
I have been trying to check my oil level for a couple days now, but each time the dipstick comes out very dry. I'm not getting a yellow oil light to indicate that the oil is low. I service the car recently and replace with the correct amount of oil, and i'm not seeing any oil leak.
What is happening here, car has 124,000km.
auto feature is offline   Reply With Quote
Old 04-05-2013, 08:12 AM   #2
SeanC
My Ride: 330i
who serviced the car? how do you know correct amount of oil was used?
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 04-05-2013, 08:13 AM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Check the level 5 minutes after shutdown.
Old 04-05-2013, 08:26 AM   #4
AudiEtr
My Ride: 330i
Put more oil in it! If you go to far drain some out. Do not trust a dash light or lack there of. I would not drive it until you know for sure. You could also just drain it to see how much is actually in there.... It's the oem dipstick right?
AudiEtr is offline   Reply With Quote
Old 04-05-2013, 08:39 AM   #5
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
^^^ +1
Try adding a quart and see if the level comes up. Should take 7+ quarts when servicing.
HacksawMark is offline   Reply With Quote
Old 04-05-2013, 08:52 AM   #6
auto feature
The correct amount of oil was added, i'm always there when my car is been serviced, and i buy the parts myself. Yes, it is the oem dipstick.
Old 04-05-2013, 08:53 AM   #7
auto feature
Originally Posted by hacksawmark View Post
^^^ +1
My car is a 318i, it uses less than the 7quarts.
Old 04-05-2013, 09:15 AM   #8
Llink78
My Ride: 2002 330i
the 318 a 4 cylinder right?
Llink78 is offline   Reply With Quote
Old 04-05-2013, 09:32 AM   #9
auto feature
Yes.
Old 04-05-2013, 09:42 AM   #10
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check the level and condition of your coolant. Has your car ever been overheated?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-05-2013, 09:43 AM   #11
HacksawMark
My bad for not noticing.
Old 04-05-2013, 02:06 PM   #12
auto feature
Never mind guys, it's a clogged oil dipstick tube, based on my research, it seems to happen with these cars.
Old 04-05-2013, 02:31 PM   #13
benzedid
My Ride: 2001 BMW E46 318i
Then that's bad news. If it happened to be clogged, possibly there is a lot of sludge built up in the engine. How often do you change the oil? I got a 318i too and I change it on every 4,000 Km.
benzedid is offline   Reply With Quote
Old 04-05-2013, 03:54 PM   #14
jdstrickland
My Ride: '94 325iC & '00 323i
Clogged tube? Really? I've never heard of such a thing. The dipstick should pass all of the way through the tube and be submerged into the top of the oil, if the top of the oil is near the tip of the dipstick. Reading oil level does not depend on the oil going up into the dipstick tube. Is it possible that the dipstick tube can have debris on it that wipes the oil off as the stick is pulled out? I've never heard of this happening.
A cure for such a thing might be to push a piece of tissue paper and force it through the tube to clear any debris that might be inside. The downside of this is that tissue will be collected in the oil filter, which should not be a big deal. Changing the oil in a 1000 miles or so will correct this. I think the tissue will be beat to crap so badly that it won't be a problem, but there's the outside-chance however remote that it could become lodged somewhere. I don't think it will get out of the oil pan, to be honest, but if it does then it will be trapped by the filter.
Old 04-05-2013, 05:22 PM   #15
WDE46
Could also use a .30 cal (7.62mm) rifle cleaning swab on a flexible shaft. May be too narrow IDK.
Old 04-05-2013, 07:08 PM   #16
lszlszx
My Ride: 1.8T, XC70
He might be referring to the lower oil return hose.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-05-2013, 07:15 PM   #17
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Not seeing clogged guidetube as reason for no oil on dipstick, unless you mean your ccv isn't working and you've lost a lot of oil in a short time.
But, next time you change oil...drain it completely, add specified amount, start car, let it cool and see where it shows the next morning to 'calibrate' your dipstick...just to make sure you have the right one. I didn't.
Also, please don't stick anything down your guidetube. If it's clogged, it's clogged in the tube within a tube from below the drain tube from ccv. You won't clean that with tissue or gun cleaning thing...your dipstick does there anyway.
Only way to clean it is to remove it and spray the hell out of it with parts cleaner. But, at that point, you should be thinking of replacing entire ccv system.
HTH
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-05-2013, 08:45 PM   #18
Brevik
My Ride: Tiag M3
I would not just brush this off so quickly, try the gun cleaner as suggested.
Brevik is offline   Reply With Quote
Old 04-05-2013, 10:07 PM   #19
WDE46
No dmax is right. My suggestion wouldn't do anything that the dipstick isn't already doing. I think.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-06-2013, 02:19 AM   #20
taibinhvuong
My Ride: E46 99' 328i
It is not a good idea to be guessing here, the best way is to completely drain out the oil, refill about 6 quarts and use the dipstick to measure to see that there is still no oil on dipstick (I highly doubt it), and top off as needed.
If there is still no oil on dipstick, you really have some mystery problem that need to be investigated.
My car uses exactly 6 quarts rather than 6.9 quarts that other people claimed.
taibinhvuong is offline   Reply With Quote
