Old 04-05-2013, 12:40 PM   #1
330CSL
My Ride: 03 330ci
Alternatives to ATI Damper
Hey Guys,
I was wondering is there any alternatives to the ATI damper. I have the AA tune but rarely take my car past 6500 Revs after hearing all the horror stories and frankly not being able to afford catastrophic failure on my daily driver and only car. I would like some piece of mind short of ordering the ATI damper as I still need to refresh my cooling system and have some other pressing preventive maintenance items first I need to take care of. Any advice would be great.
Best,
Justin
330CSL is offline   Reply With Quote
Old 04-05-2013, 01:40 PM   #2
SoloII///M
My Ride: Many
Keep the revs down. That's your alternative.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 04-05-2013, 01:44 PM   #3
mkodama
mkodama's Avatar
As far as already built, not many. ATI is the only as far as I know.
But you can have something custom made probably by many of the companies. There are rubber weighted dampers like ATI, but also fluid dampers, and rotating weight dampers, all with their supposed benefits.
Piece of mind would be doing something to better lock the oil pump nut onto the oil pump shaft, which is probably all that's needed on a street car.
Old 04-05-2013, 05:00 PM   #4
330CSL
My Ride: 03 330ci
Yes, my shift points are at 6k when going WOT but it sometimes slips a bit further into red....I'll guess I'll just have to throw in on the list of things that need to get done on the car. Thanks for the quick replies.
Old 04-12-2013, 10:21 AM   #5
Blocked Out
My Ride: Imola 330i M-Sport
Why would you want to rev pass 6500? Your can makes peak power at 5800 and your most usable rpm band is 4500-5800.
The only reason why youd ever want to rev over 6000 is if you are doing a flat out run on a closed airport runway
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 04-24-2013, 03:03 PM   #6
TerraPhantm
My Ride: M3 & ZHP
Take gear multiplication into account. Your car is going to be making more torque at the wheels at 6500 in 2nd than it will at 5900 in 3rd. So it will still technically accelerate faster if you shift at red line. It also allows you to be closer to peak power in the next gear
Old 04-24-2013, 10:12 PM   #7
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
What does this have to do with an alternative to an ATI damper?
Old 04-24-2013, 11:42 PM   #8
TrippinBimmer
My Ride: Just Fast!
I know of an alternative solution. OEM serious...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 04-24-2013, 11:53 PM   #9
F1004fun
My Ride: '02 330Ci
Originally Posted by 330CSL View Post
Hey Guys,
Best,
Justin
Hey Justin
I felt the same way as you, so I ordered up a ATI myself. In fact I was the guy that had to pay the extra $100 for them to build the first full street version. It made the harsh harmonic feel of the engine at 6k+ better but with our aluminum engine blocks and long strokes what really can you do. You can hold an stock iron block S52 at 6500 and it's smooth in comparison to our aluminum block motors.
I would honestly just wire, weld, VAC, or Vaio??? your oil pump and drive worry free. The motors left the factory with roughly the same balancing practices, so it will hold together.....just feels like it won't.
Of the other things I did to make the engine feel smoother are a hydraulic main belt tensioner assembly, an E46 M3 timing chain tensioner, and believe it our not an over-running clutch alternator pulley from a VW diesel engine.
F1004fun is offline   Reply With Quote
Old 04-25-2013, 12:44 AM   #10
Iceman00
Banned User
My Ride: E90 6MT
Don't use a LTW flywheel.
Old 04-27-2013, 01:37 PM   #11
TerraPhantm
My Ride: M3 & ZHP
The guy I quoted said there's no reason to drive past 6K RPM (and therefore no need for an improved vibration damper) due to the M54's power curve. I refuted that.
