Sponsored by BimmerWorld
Old 05-08-2013, 08:59 PM   #21
drumsauce
My Ride: 2000 323it
Originally Posted by kfiggins View Post
+1
+2
Had EXACTLY the same problem with my Bilstein Coilovers.
Exhibit A:
Make sure you have the TWO washers installed. =)
drumsauce is offline   Reply With Quote
Old 05-10-2013, 02:35 PM   #22
The_W_95
My Ride: 2003 330i
Pooping noise when I turn at low speeds
Originally Posted by drumsauce View Post
+2
Exhibit A:
Don't think I transferred the washer over, I didn't even take my stock struts apart. Is it a specific washer or will any washer work?
The_W_95 is offline   Reply With Quote
Old 05-10-2013, 11:43 PM   #23
drumsauce
My Ride: 2000 323it
What coilovers are you using? With my Bilstein PSS coilovers, I HAD to take the stock upper spring perches and bearing off of my stock set up, and transfer it to the coilovers. When I did this, I failed to used both washers between the bearing and the upper spring perch. (as seen in the pic...spring perch is on spring, bearing is on ground...washers in between).
Yes, they ARE specific. One is slightly curved to go on the bottom of the bearing for the rollers to roll, and the other is flat, but helps raise the bearing high enough to keep the bearing from scraping the perch.
Old 05-11-2013, 05:07 PM   #24
The_W_95
My Ride: 2003 330i
I'm using racelands
Is it 5 & 6 I need?
Old 05-11-2013, 06:43 PM   #25
drumsauce
My Ride: 2000 323it
Yes.
Old 05-11-2013, 11:20 PM   #26
The_W_95
My Ride: 2003 330i
Okay parts are ordered, fingers crossed this solves the problem!
Old 05-21-2013, 07:07 PM   #27
Weralkstterb
My Ride: 2000 328ci
Poop regulator switch probs
Weralkstterb is offline   Reply With Quote
Old 05-22-2013, 05:39 PM   #28
ca5ua1ty
My Ride: 2001 330CI
I had this problem on my old Acura. It was actually due to me not lining the springs up properly and putting the rubber end peices on after i installed the lowering Eibach springs.
http://forums.clubrsx.com/showthread.php?t=583436
"Most people who install springs will for get to grease up where the springs hit metal.. If your springs do not have the rubber on the ends then after your springs set they will shift under the awkward pressure... The knocking noise is your spring moving. If your springs came with he rubber coating on the ends all you need to do is jack up the front and give it a good spray of grease so it stays in place.... if you don't have the rubber on there then you can take the rubber off your stock springs and put them on ur new ones, but that would involve reinstalling."
That might help...
"In a world full of ordinary, you need to stand out with something a little extraordinary."
ca5ua1ty is offline   Reply With Quote
