Old 04-05-2013, 01:27 PM   #1
Serg323
My Ride: BMW 3 Series
Will 17" BBS wheels off a 97-03 bmw 5 series fit on a 2000 323i?
Serg323 is offline   Reply With Quote
Old 04-05-2013, 01:31 PM   #2
SilverThreeTwoFive
My Ride: 2002 BMW 325i
Just about anything will fit anything else. I was pretty excited when I found out too
http://lugpattern.net/BMW_Bolt_Patterns.htm
SilverThreeTwoFive is offline   Reply With Quote
Old 04-05-2013, 02:17 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Depends on the offset. Some offsets may fit, others may require spacers, others will not be compatible. It's not just about bolt pattern. It's a combination of tire width, wheel width, wheel size, and wheel offset.
Basically, we don't have enough information to say yes or no to this question.
Old 04-05-2013, 02:46 PM   #4
SilverThreeTwoFive
Oh yeah. I forgot about fitment and just assumed he meant lug pattern.. Sorry! Although if we learn anything from the stance guys, anything can fit on anything. It's just a matter of how clownish you want it to look. Not trying to hate on stance, but -12* of camber does not look good on anything.
Last edited by SilverThreeTwoFive; 04-05-2013 at 02:47 PM. Reason: Defend from accusations that I was sippin' dat Hatorade
Old 04-05-2013, 03:03 PM   #5
lmr2wil
My Ride: '00 328Ci
Camber and offset have nothing to do with each other.
OP - see http://felgenkatalog.auto-treff.com/ for lots of info on OE Wheels - including offsets.
Luke
lmr2wil is offline   Reply With Quote
Old 04-05-2013, 03:09 PM   #6
SilverThreeTwoFive
Well if you have a radical offset you're going to typically need either more camber or fender rolling/pulling (often both) to pull that wheel back under the lip of the fender aren't you? So while they're not NECESSARILY connected they can and do work together a lot within the stance community in order to achieve the looks they want
Old 04-05-2013, 03:12 PM   #7
qthegenius
My Ride: E36 M3, E46 323i
no, they won't fit directly. The hub diameter on the e39 non-M5 is 74.0mm, while every other modern BMW is 72.4mm. You'll need to get some hub centric rings as adapters.
http://www.e30tech.com/forum/showthread.php?t=104636
qthegenius is offline   Reply With Quote
Old 04-05-2013, 03:44 PM   #8
lmr2wil
My Ride: '00 328Ci
They aren't connected. As you point out, you an use camber as a bandaid for poor wheel choice - but changing offset doesn't change camber nor does changing camber effect offset.
Old 04-05-2013, 05:21 PM   #9
WDE46
He never said that offset changes camber. He merely poked fun at stancers in saying that you can get a ridiculous offset to "fit" by leaning it in with extremely excessive camber.
Old 04-05-2013, 06:42 PM   #10
SilverThreeTwoFive
Thank you
Old 04-05-2013, 06:52 PM   #11
zhenkaaaM3
My Ride: Fst'r then your e46
Yes they will fit just fine. Make sure to buy the hub centric rings on from a 72.5 to 74.1. Your steering wheel will vibrate like crazy at 50+.
and they will fit fine. The offset is +20 though.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
