Old 04-05-2013, 08:16 PM   #1
E46-MOTOLING
My Ride: 2000 / 318i
Temperature needle problem - M43 engine
Can anybody tell me why the temperature needle rise to a high level when the engine is cold?
When opening the key to on, right up until the temperature needle into the red.
What's the problem with a heat sensor?
Thanks in advance.
E46-MOTOLING is offline   Reply With Quote
Old 04-06-2013, 09:47 PM   #2
E46-MOTOLING
Old 04-06-2013, 09:57 PM   #3
lszlszx
My Ride: 1.8T, XC70
It might be the engine coolant temperature sensor, or the wiring to the sensor. Does it change with the engine running?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-07-2013, 12:01 AM   #4
E46-MOTOLING
Is the number 13 is designated temperature sensor is the purpose?
The engine is cold or being on the run, the position of the temperature needle stuck in the red.
*13 Part 13621433076
Old 04-15-2013, 12:55 PM   #5
Iggy27
My Ride: 2003 330xi
Mine does that too! But my thermostat is stuck open so my engine stays around 70 degrees could that be playing a role? And what is the little cylinder thing that goes into the bottom of the expansion tank? Is that a sensor also? Cause I broke mine in half but do I need it?
Iggy27 is offline   Reply With Quote
Old 04-15-2013, 01:04 PM   #6
NumbaOneNewb
My Ride: 2003 330CI Silver
I believe there's also a thermostat in our expansion tank. how did yours broke in half?
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-15-2013, 01:05 PM   #7
Iggy27
My Ride: 2003 330xi
Ha taking out my expansion tank haha and the car had 130000 miles so I think that also played a role in breaking it
Old 04-15-2013, 01:07 PM   #8
Iggy27
My Ride: 2003 330xi
This thing, do I need to fix it?
Old 12-09-2014, 08:09 AM   #9
mandla24
My Ride: BMW
Temp gauge problem
My BMW 318 also has the same problem. How were you able to solve it in your car? Please kindly advise.
mandla24 is offline   Reply With Quote
Old 03-20-2015, 10:47 AM   #10
BMW_E46_DK
My Ride: BMW E46
Hi,
My E46 did this last month. I have a 316i 1.9 with the M43 engine from year 2000. Here is what I did to solve the problem.
I replaced the temperature sensor (part 13), shown at the picture below:
How to do it:
Remove the air intake.
Remove the throttle housing.
Remove the upper part of the intake manifold.
After removing these parts you are able to remove the temperature sensor water/oil.
It can be a little tricky, but is manageable.
What you need (except a new temperature sensor):
Four new profile-gaskets (number 7 shown below)
At the same time I drained the cooling system and replaced the thermostat housing (as part of the general maintenance of the car).
The repair is not that complicated, and by I believe you can save a lot of money by doing it yourself
BMW_E46_DK is offline   Reply With Quote
Old 03-20-2015, 11:08 AM   #11
mandla24
My Ride: BMW
Temperature Needle
Thanks for kindness in taking your precious time to give such a superb explanation. I will order the Engine temperature sensor and will then give you a feedback once I am done with this project
