///M3 Forum
Old 04-08-2013, 12:55 PM   #1
xsxpxhx
My Ride: 2002 M3
Car died while driving
So Its at the Indi shop right now. But as I was driving the car just stalled. After it stalled I tried turning the car on but it turns on for about 3 seconds and then it turns off. I dont think it could be the battery since I just replaced it last month (unless I ws sold a dead Batt) Any Idea what it could be? My best bet is the alternator, or it really is jsut a dead battery. Any other possibilties? Thanks alot guys. Happy safe motoring to you all!
xsxpxhx is offline   Reply With Quote
Old 04-08-2013, 01:15 PM   #2
DSilk56
My Ride: M-3 Convertible
Does the engine crank over normally when you turn the key? If not, your battery is likely dead. If the battery was new, then the most likely culprit would be your alternator. If the alternator stops working, then the car runs off of the battery until the battery dies. If, however, the engine cranks normally, then the problem is elsewhere, and you need to track down the usual suspects. First pull whatever codes appear of the on board computer, and see what they say. Does the car have fuel? Check the tank (the gauge may not be working properly). If so, are the injectors getting fuel? Check the fuel pump to see if it is operating. If so, check the fuel lines to make sure that there is no blockage. Is the car getting spark? Check the coil/plug packs. Good luck.
DSilk56 is offline   Reply With Quote
Old 04-08-2013, 01:22 PM   #3
xsxpxhx
My Ride: 2002 M3
Thank you Dsilk!
Yes, the car does get a good crank sound. then the car sounds like its struggling to run then it dies. I just only hope for the best. Thank you!
Old 04-08-2013, 02:08 PM   #4
E46@46
My Ride: 2003 325xiT
Originally Posted by xsxpxhx View Post
Thank you Dsilk!
Sounds like a fuel pump. They usually fail fast and I've had it leave me stranded twice (in 2 different) bimmers. When you move the key to position 2, you should hear the pump prime from under the backseat. Remove the seat cushion for a better result.
E46@46 is offline   Reply With Quote
Old 04-08-2013, 03:03 PM   #5
xsxpxhx
My Ride: 2002 M3
Thank you for the info E46. How much did that cost you? Fuel pump I mean?
Old 04-08-2013, 03:53 PM   #6
DSilk56
They run around $300 - $350.
Old 04-08-2013, 04:02 PM   #7
GEEZ_ITS_A_BMW
My Ride: 2000 323I
I just ordered a OEM fuel pump and gasket for $140 free shipping from bma parts.
Make sure you also replace the fuel filter
GEEZ_ITS_A_BMW is offline   Reply With Quote
Old 04-08-2013, 05:17 PM   #8
E46@46
About $150 from AutoHausAZ.
Old 04-09-2013, 10:34 AM   #9
ZkansasZ
My Ride: a horse
could you please post the link?
It's showed on that site:
Part Number Brand / Description / Restrictions List Core Your Price Qty Select
16142229684
Genuine BMW
Fuel Pump Assembly; Right Side Suction Device with Main Fuel Pump
1 per car. Limited availability. $406.40
$399.87
SALE
02AccordV6(sold) 03350zMT(sold) 04E46///M3MT(sold) 06RSXauto 07G35auto
ZkansasZ is offline   Reply With Quote
Old 04-09-2013, 11:02 AM   #10
E46@46
16142229684
Genuine BMW
$399.87
SALE
My error, it was defaulting to a non-M vehicle. Sorry about that. Your price is accurate.
Old 04-09-2013, 12:16 PM   #11
xsxpxhx
My Ride: 2002 M3
I ordered it. It was the fuel pump that was the problem. Thank you E46@46!
Old 04-09-2013, 12:40 PM   #12
E46@46
Glad I could help. This forum has saved me big $$ with help. Easy DIY also.
Old 04-09-2013, 02:28 PM   #13
ZkansasZ
My Ride: a horse
oh lol it's all good bud! I was excited for a second lol
