///M3 Forum
Old 04-09-2013, 08:17 AM   #1
Fantom.
My Ride: 2003 M3
Leaky M3
Hi All,
I recently bought an M3 and it has developed a leak in the engine bay, Im not quite sure what it is exactly that is leaking but here is a pic:
Would appreciate if anyone has any advice on what it is and how to fix it?
Thanks in advance
Fantom. is offline   Reply With Quote
Old 04-09-2013, 09:11 AM   #2
cold m3
My Ride: E46 ///M3
power steer hoses
Photos of My ///M3
cold m3 is offline   Reply With Quote
Old 04-09-2013, 10:07 AM   #3
Fantom.
My Ride: 2003 M3
Originally Posted by cold m3 View Post
power steer hoses
Thanks for that I will look into how its happened
Old 04-09-2013, 10:19 AM   #4
Fantom.
My Ride: 2003 M3
Has anyone seen a leak like this here before? would the pipe be split or is it likely to be a connection (o-ring) that has blown?
Old 04-09-2013, 11:13 AM   #5
dillard
My Ride: 2004 M3 Cabrio
Add your leak here once you get it solved.
http://forum.e46fanatics.com/showthr...583&highlight=
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 04-09-2013, 11:26 AM   #6
Fantom.
My Ride: 2003 M3
Are you sure its power steering as it goes towards the radiator...
Old 04-09-2013, 06:12 PM   #7
Fantom.
My Ride: 2003 M3
Ok, so I have figured out that it is the PAS cooling pipe coupling that is leaking, does anyone know how the coupling seals? it looks like there is a flange on the male hose but Im not sure how it is removed?
Old 04-09-2013, 06:59 PM   #8
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
http://www.amazon.com/Trans-Cooler-L.../dp/B002UBO1WA
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
