Old 04-09-2013, 03:34 PM   #1
ChrisDinan
My Ride: 330 Dinan Coupe
I drove through some water and my car wont stay running now
I already replaced the spark plugs and oil after removing one at a time while cranking to get rid of any water inside. I dont have any codes coming up on my obd2 and my exhaust still spits little sprays of water when revving at high rpm. I got her driving again on the freeway, but when come to a stop/idle itll cut out... (also have replaced my fuel filter few weeks ago) I'm hella lost on this
ChrisDinan is offline   Reply With Quote
Old 04-09-2013, 03:44 PM   #2
Fergo
Banned User
My Ride: still a gay 135i
How deep was the water?
Fergo is offline   Reply With Quote
Old 04-09-2013, 03:47 PM   #3
ChrisDinan
6-8inches prolly. Rain run off in my alley
Old 04-09-2013, 03:52 PM   #4
ChrisDinan
My intake sits right off the ground
Old 04-09-2013, 03:56 PM   #5
TrickTizzle
My Ride: 325i
Class of 2013.
Old 04-09-2013, 03:56 PM   #6
JJR4884
My Ride: BMW
JJR4884 is offline   Reply With Quote
Old 04-09-2013, 04:05 PM   #7
Fergo
Banned User
well. Lol you ruined your engine. Ever thought why the factory air box is where it is?
Old 04-09-2013, 04:30 PM   #8
3coupe
My Ride: 330Ci
I would recommend cleaning your MAF. My car was idling rough (no codes) so I cleaned the MAF and it ran fine after.
Since your car is still running you may have gotten lucky. Now learn your lesson and don't run an intake that is inches off the ground because people here say you'll gain 1-2hp.
3coupe is offline   Reply With Quote
Old 04-09-2013, 05:32 PM   #9
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
But... but.... Racecar!
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 04-09-2013, 07:46 PM   #10
TallSkinnyMatt
My Ride: E92 M3 ZCP
This.
Now go back to factory airbox. Or get a BMW performance or Dinan High Flow if you absolutely need an intake.
TallSkinnyMatt is offline   Reply With Quote
Old 04-09-2013, 09:10 PM   #11
djnekkon
My Ride: MB3ci & z33 HR
Old 04-10-2013, 06:04 AM   #12
330xIce
My Ride: 2005 330xi
Genius ^
Sent from my ADR6425LVW using Bimmer App
-James-
Old 04-10-2013, 06:09 AM   #13
cak323i
My Ride: ///M3 & 330i ZHP
Originally Posted by TallSkinnyMatt View Post
This.
This is what I would consider doing if I were you. If you have lots of running water where you live it does not make any sense to have your intake sitting right off the ground No wonder you're having issues now....not good to suck in water through your intake....
Now this is a funny pic! I wouldn't recommend doing this though...
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 04-10-2013, 07:55 AM   #14
THECLEANERBEAMER
My Ride: 2002 325i
Did you not slow down and go like 2 mph through the water? Or did you drive fast through it?
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 04-10-2013, 08:18 AM   #15
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, if you're lowered and had intake in the water...I don't know what to say.
I hope that if you keep it running on the freeway a while longer you'll vaporize the water and maybe get lucky.
Add Techron to your fuel as per instructions.
Return intake to stock, or at least lift it up where it goes...paper filter please.
So I've read that old timers used to spray water into intake as a way of knocking the carbon off.
BTW, those instincts you didn't have about the creek that runs in your alley...don't forget about your car next time. If need be, drive it up a ramp before the next monsoon.
And I'd probably change the oil again if it was me.
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 04-10-2013, 09:04 AM   #16
Gottalovethexi
Gottalovethexi's Avatar
My Ride: 03 xi & 72 Bav
E46fanatic of the year.
Old 04-10-2013, 09:28 AM   #17
NumbaOneNewb
My Ride: 2003 330CI Silver
I may consider doing that dual intake on my roof like that celica. I bet you that must've added like 20 HP
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-10-2013, 10:07 AM   #18
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Ah, finally a snorkel option. Handy for fiording streams and rivers.
HacksawMark is offline   Reply With Quote
Old 04-10-2013, 10:38 AM   #19
dmax
dmax's Avatar
When I ford fjords, my exhaust tips sit in the water, but with my helium filled tires, it will float in 2'3" of water and the exhaust propels it.
Of course this is kind of risky to do, and you need to seal up some holes carefully (wine corks work great...with a dab of rtv on them). Stock intake is fine as long as there aren't any waves.
dmax on Facebook
Mangofy your E46!
Old 04-10-2013, 12:07 PM   #20
wildirish317
My Ride: 2004 325Ci vert
I can't believe you said that!
Yeah, we used to do this, back when compression was 8.5:1 and we didn't have computerized fuel metering, so we ran everything rich.
Don't pour water into your intake.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
cutting out, water, water in exhaust, water in intake
