Old 04-09-2013, 09:42 PM   #1
Kevinheidari
My Ride: 2002 325i
One angel eye flicker!
While I love them, my Orion Lite angel eyes have an issue where just one side flickers like a damn strobe light while on. I switched out the inverter or ballast (whatever you call it) to the opposite side and the problem is gone. My wiring/grounds are not an issue as I have had no problems for quite a few months prior plus I've looked at and checked all grounding as well.
Anyone else have this issue?
Thanks!
Kevinheidari is offline   Reply With Quote
Old 04-10-2013, 08:24 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If the problem went away then the circuit board part from the wire harness to the angel eye connectors probably has to be changed.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 04-12-2013, 01:50 AM   #3
Kevinheidari
My Ride: 2002 325i
Thanks for the input Jake.That's my thought as well. Only thing is where can I get a replacement ballast/inverter? I ended up disconnecting both sides due to the flickering for now.
i ordered a set of these: http://www.elwirepros.com/halo-inverter.html
But upon wiring them up they barely light up/work.
Old 04-12-2013, 12:19 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Hmm, don't think that will work for LED angel eyes.
Old 04-12-2013, 11:25 PM   #5
Kevinheidari
My Ride: 2002 325i
Any idea on where to get some replacements?
