Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-10-2013, 08:35 AM   #1
Guest100615
Account closed per your request
fluorescent lights
Last week a guy replaced the fluorescent lights in the men's room.
The lights work, but they don't light up a hundred percent.
Only about 25 percent as bright as they should be.
Does the lighting fixture need to be replaced ?
What's the problem ?
Thanks.
Guest100615 is offline   Reply With Quote
Old 04-10-2013, 09:06 AM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
pull out, reinstall, wiggle
still not working right?
balast
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 04-10-2013, 09:35 AM   #3
Guest100615
It might be the ballast. the lights worked fine until yesterday.
Maintenance can figure it out, but I like to know how to figure things out for myself too.
Old 04-10-2013, 10:25 AM   #4
WerksM3
My Ride: 2002 M3
Most likely it's the ballast, however the newer fluorescent bulbs take longer to "warm up" and get bright when installed on older (non-electronic) ballasts.
If you end up replacing it get a fixture with an electronic ballast. It will last a lot longer and the "strike" power is much higher giving you brighter light when you flick the switch.
WerksM3 is offline   Reply With Quote
Old 04-10-2013, 10:28 AM   #5
ryanwhite74115
My Ride: 2013 Infiniti G37S
Probably the ballast
ryanwhite74115 is offline   Reply With Quote
Old 04-10-2013, 11:26 AM   #6
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Ironic, but this advice actually helps resolve another issue in the mens room too
JonJon is offline   Reply With Quote
Old 04-11-2013, 09:35 AM   #7
GlockMan
GlockMan's Avatar
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
