Ran over a piece of glass on top portion, is the tire alright/ pics included - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 04-10-2013, 04:42 PM   #1
tommasomartello
My Ride: Dodge
Hello, I ran over a piece of glass on the top portion of the tire. I do not believe this is the sidewall. I took the two chunks out with a small pick. It took two small scoops out. Is this alright to drive on?
So far no air is losing...
tommasomartello is offline   Reply With Quote
Old 04-10-2013, 07:33 PM   #2
nlav26
My Ride: 2001 330i
I think it's safe to say you'll be alright, but definitely wait for some other opinions here.
stahlgrau ~ tannin
nlav26 is offline   Reply With Quote
Old 04-10-2013, 07:36 PM   #3
FastHackem
My Ride: E60 M5
Yes you're fine. Nice clear pics!
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-10-2013, 08:13 PM   #4
stoner4567
My Ride: 76 2002 and 04 330i
YOU'RE DOOMED! Go buy new tires ASAP but for the love of God don't drive there on those things!
stoner4567 is offline   Reply With Quote
Old 04-10-2013, 10:56 PM   #5
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
I can't see any damage from the fuzzy-blurry pics. You should be fine.
HacksawMark is offline   Reply With Quote
Old 04-10-2013, 11:09 PM   #6
tommasomartello
My Ride: Dodge
I will repost the pictures with a black circle highlighting where the issue is. The location is sort of where the sidewall and the tread meet, but on top.
Imagine where the black circle is, I ran over soem glass that was lodged in. I took a small pick and scooped the glass out, but some rubber came out too. According to the TPMS, there is no air missing. Please help.
Old 04-10-2013, 11:10 PM   #7
kejobe
My Ride: 2003 325I
Should be fine, but to make sure, stick a small flat head screwdriver in the hole and see how deep it goes. If its deeper than the tread, it's best to replace it. If not, it should be fine. And FYI, no that isn't considered the sidewall of the tire.
All Stock...
kejobe is offline   Reply With Quote
Old 04-10-2013, 11:11 PM   #8
tommasomartello
My Ride: Dodge
Old 04-10-2013, 11:11 PM   #9
2003 325i
My Ride: '03 Orient Blue 325i
spray with soapy water, if not leaking you're ok.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 04-10-2013, 11:11 PM   #10
tommasomartello
My Ride: Dodge
if that is not the sidewall, then what is it
Old 04-10-2013, 11:12 PM   #11
tommasomartello
My Ride: Dodge
if I spary it with soapy water and there is a problem, will it bubble?
Old 04-10-2013, 11:14 PM   #12
2003 325i
now you're using your noggin.
Old 04-10-2013, 11:16 PM   #13
kejobe
My Ride: 2003 325I
That is still part of the tread. It will only bubble if there is an air leak. If it is leaking air, it'll need to be replaced. It is NOT recommended to plug a hole with-in 1" of the sidewall. It'll screw the belts and cause a possible blow-out.
All Stock...
Old 04-10-2013, 11:26 PM   #14
tommasomartello
My Ride: Dodge
Kejobe, if it is not considered the sidewall and it is part of the tread
if there is an issue why will a plug not be helpful.
-But besides that, if I am not leaking any air is there any danger driving with some chunk taking out due to glass removal, so close to the sidewall.
You see behind where I am pointing on the tread pattern there are what looks to be small holes that came already on the tire on the square patterns. What I did is deeper than that, but I dont think air is leaking out.
Old 04-10-2013, 11:29 PM   #15
2003 325i
you'll be fine.
Old 04-10-2013, 11:33 PM   #16
tommasomartello
My Ride: Dodge
Do cords run across sidewal or where there is tread too? I was wondering if I should be looking for this in that area
Old 04-10-2013, 11:35 PM   #17
kejobe
My Ride: 2003 325I
If it's not below the depth of the tread block it should be fine.
And yes, that is still the tread. BUT, there are belts under the tread. When a plug is used it will separate a hole in the belts. This works fine towards the center of the tread. If it's done towards the edge, it will create a bulge. It may not be noticeable when done. BUT, it can and has caused the belt and tread to separate. This can and has caused the tread to fly off the tire. You can imagine what could happen if that happens.
As I said, you need to check and see how deep the hole is. If it is deeper than the tread block, personally I would not trust it and get another tire. If it is the same depth or shallower than the tread block, it should be fine.
All Stock...
Old 04-11-2013, 12:54 AM   #18
tommasomartello
My Ride: Dodge
Actually maybe this is called the Shoulder of the tire?
Old 04-11-2013, 01:26 AM   #19
HacksawMark
See if you can gauge the depth of the cut. If it's no deeper than the tread depth, you're fine and have nothing to worry about. If you're still a little concerned, put the affected tire on the rear in case it blows out; you'll be less apt to lose control. If you're very concerned, get a new tire to replace it.
Old 04-12-2013, 04:20 PM   #20
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
OP, it's really hard to tell based on your pics. They're all blurry haha. It looks like that's on the tread though.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
