E46 Xi Forum
Old 04-11-2013, 09:40 AM   #1
SeattleLSB
My Ride: 2003 330XI, 2003 M3
OFHG XI Specific
Any tips of advice for this project? I did a search and most of this stuff is RWD specific.
Should we pull the entire housing? What is the best way to address the PS pump? Some people say pull it up and unbolt?
Any advice is welcomed!
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 04-11-2013, 10:35 AM   #2
oafmanwpr
My Ride: 2003 330xi 6sp manua
I did my 330xi last fall. It's the same procedure. You can just unbolt the ps pump and move it out of the way. I did not remove the oil filter housing completely , just pulled it away from the block enough to clean it up and get the new gasket in. Keep track of the bolts. They are all different lengths and when re-assembling torque to spec in stages from alternating sides of the housing. You want to spread the torque as evenly as possible. It's a good time to replace the vanos oil line & crush washers while you're in there, adds 10 minutes of work. Use some brake cleaner to get all oil residue off the engine and everything it dripped on. Then you can easily spot any future leaks.
oafmanwpr is offline   Reply With Quote
Old 04-11-2013, 11:37 AM   #3
mmaldin
My Ride: '04 325xit '94 325i
I did mine last week. There are many good diy's. The xi is the same procedure. The only difference I encountered from the diy I followed was that the bottom bolt holding on the ps pump was accessed from above rather than under the car.
Yes you do want to remove the housing. And do keep track of the bolts as earlier mentioned.
Sent from my Nexus 7 using Bimmer App
mmaldin is offline   Reply With Quote
Old 04-11-2013, 12:34 PM   #4
Kubica
My Ride: 2003 325xi
Leave the pump attached to the housing. You will have enough room to change the gasket without unbolting the pump or removing the whole housing from the engine bay.
Old 04-11-2013, 01:34 PM   #5
DavidDee
My Ride: 2004 325xi
+1
You don't need to remove the pump. I had plenty of room without removing it. Make sure to give everything a good cleaning while you're in there!
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 04-11-2013, 07:40 PM   #6
Foxtrot_Uniform
My Ride: 325Xi
Yup... I just did this job on mine this past Saturday. I had more room as I was also doing a cooling system refresh and had the fan, radiator, etc. out too.
Take your fan off, remove your belts, take your airbox out, remove the two bolts for the PS reservoir and let it fall over to the fender well... Remove your alternator and you you'll have the 6 bolts holding on the housing and two bolts holding the PS pump and the one coming up from the bottom. You might have more room as well if you remove your top radiator hose too...
Allow yourself 4-5 hours minimum if you have never done this. I read somewhere that BMW techs get paid 8 hours for the job. (Though a post around here shows around 3) After doing it once now I'd almost bet I could do it in 2-3 hours.
Foxtrot_Uniform is offline   Reply With Quote
Old 04-12-2013, 01:23 PM   #7
Kubica
My Ride: 2003 325xi
^no need to remove the three bolts that hold the pump to the housing.
Old 04-12-2013, 08:18 PM   #8
SeattleLSB
is it best to remove it if i'm doing the CCV at the same time?
Joe
Old 04-13-2013, 03:03 PM   #9
KaktusJaque
My Ride: 2003 325xi
search Youtube, there is a real good video on this.
*KJ---Don't Believe Everything That You Think! *
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Clean Your Dirty Wheels
2003 Touring 325 XiT (KJ's Ride)
2004 Coupe 325 Ci (Mrs. KJ's Ride)
KaktusJaque is offline   Reply With Quote
Old 04-13-2013, 08:31 PM   #10
Kubica
My Ride: 2003 325xi
Joe
Should be fine without removing, but it'll be easier to get the bottom bolt from that position if you do want to remove it.
Old 04-14-2013, 09:14 PM   #11
SeattleLSB
The seal did not appear leaking when i removed it but with 195k on the car I replaced it anyways. The CCV system on the car was 100% orginal and never been remove, I can tell from the way the clamp was on the intake boot was facing down. I replaced the entire CCV system. Both upper and lower intale bellows were cracked, I had lower on-hand but ordered the upper.
Part # 11617503622 is cracked but I'm not sure if I can use normal vacumm hose or should I pay $18 for the BMW Piece. Both
Last but not least, does anyone know what the Vacumm line that came with the CCV kit is for? Clearly the extra port on the CCV is blocked with a plug to prevent me using it?
Joe
Old 04-24-2013, 04:12 PM   #12
mapleblunt46
My Ride: 2000 328i
that was my health inspection post where they priced it for 3 hours. i decided todo it myself just a bit nervous as it is my first time doing the ofhg. any reccomendations on what ill need? i have the parts ordered,
mapleblunt46 is offline   Reply With Quote
Old 07-11-2013, 01:25 PM   #13
EDWAGON
My Ride: 2004 325xiT
BMW quoted me 416 for this job plus tax. will tackle it after I do my rear shocks on my touring
EDWAGON is offline   Reply With Quote
Old 09-02-2013, 09:30 PM   #14
EDWAGON
Just did OFHG today,didn't have any issues. Did it in about 2.5 hours. Thanks for the info on this thread . Used the you tube video as a guide .
Old 09-03-2013, 08:19 AM   #15
bostonsthename
My Ride: 2003 Jet Black 330xi
Just did my OFHG on Saturday along with an oil change on my 2003 330xi 5 speed. I removed the PS pump just to be able to completely remove the housing. Was all fairly simple just a bit time consuming taking all the parts off. Also had to run to the parts store and get a new alternator belt because upon inspection, mine was ridden with cracks. Was suffering from an oil leak and although I haven't checked since then (but I plan on checking my oil level today) I'm not getting the check engine oil light anymore after I shut the car down. Hopefully this solved my issue.
bostonsthename is offline   Reply With Quote
