Sponsored by The Tire Rack
Old 04-11-2013, 01:11 PM   #1
PiL
My Ride: 2006 | M3 | CBM
Do these need replaced?
Inner tire is worn. Should I buy replacement now, or run them a little longer?
ID:	499882   Click image for larger version
2006 | M3 | CBM | 6MT | TEIN S Tech & Koni Sport | BMS Spacers 15mmF/10mmR
PiL is offline   Reply With Quote
Old 04-11-2013, 01:43 PM   #2
kejobe
My Ride: 2003 325I
Belts will be exposed soon. Therefore they should be replaced soon. How soon? Depends on how much and how you drive. Might want to look at why it's happening also. Worn parts? Bad alignment? Etc.
All Stock...
kejobe is offline   Reply With Quote
Old 04-11-2013, 01:47 PM   #3
PiL
Thanks! Plan to upgrade suspension this Spring. Waiting for alignment and RTABS inspection until that's squared away. Probably buy new tire soon.
Old 04-11-2013, 04:32 PM   #4
Dave1027
My Ride: '06 IR zhp coupe
What's happening? I don't see any abnormal wear from the pics. Use the Lincoln head penny test method to check the treadwear. The head should be partially covered. If you can see the whole head then time for new tires. Be sure to take into acount driving conditions and style.
Old 04-11-2013, 06:08 PM   #5
My Ride: Lexus
they're cutting it close. i'd replace them in the next 1k miles or so
Old 04-11-2013, 08:55 PM   #6
kejobe
My Ride: 2003 325I
Very inside edge of tire is bald.
All Stock...
Old 04-11-2013, 10:05 PM   #7
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Technically, the tires are good till you reach 2/32 of tread depth. With the inner part wearing down so fast, the belts will show before you get there. You should take care of the problem causing the premature wear before or at he same time you add new shoes. Or else you'll have the same problems with the new tires.
Are the tires directional? If not, I would at least rotate them.
HacksawMark is offline   Reply With Quote
