Old 04-12-2013, 02:33 AM   #1
FCUK3R
My Ride: 2000 330ci
330ci steptronic only managing 0-100kmh in 9 seconds ... What is wrong??
2000 BMW 330ci
Did a 0-100 Km/h test for the first time a few nights ago. Had a passenger using iPhone as stopwatch and half a tank of gas of 98 octane; traction was turned off and steptronic tranny was in manual mode; I took off from idle (didn't hold the gas and the brake before launch like I've heard some do just lifted off brake and gassed it).
I only did one run but only managed 9.0 sec compared to a factory claimed 7.0. Ive always felt as if this car was not as powerful as it should be, especially in the low range..it just does not feel like 170 kw..although is decent in top end..
The cars motor is in really good condition according to my mechanic even for its high mileage which is 215 xxx km. (over 120k miles) Is this a contributing factor?
I know my K&N filter is filthy and i know that definitely contributed to it ( will buy a cleaner and recharge kit for it tomoz) but would that contribute to all of the 1.5-2 seconds or so in lost time?? (I expect at least a 7.5).
What else could cause this? I will check the intake pipe for cuts etc. that could lead to air leaks...but other than that i have no clue. I read somewhere that people clean their MAF sensor as this may contribute to this. How do you clean the sensor?
thanks
FCUK3R is offline   Reply With Quote
Old 04-12-2013, 02:41 AM   #2
jcns
My Ride: California
1st. Steptronic. It's slower than manual
2nd. A "filthy" air will definitely make your car slower. Trying breathing through a straw while running 1/4 mile around the track.
If you have a convertible, also slower
jcns is offline   Reply With Quote
Old 04-12-2013, 02:47 AM   #3
FCUK3R
My Ride: 2000 330ci
haha yeh point taken. nah its a coupe and i think manual factory time is 6.5 sec.
Old 04-12-2013, 02:48 AM   #4
AquaRelliux
My Ride: 330ci 03 M-sport
There is a million problems that can cause this, does the car feel sluggish and slow always on low rpm or is it only when cold? I will list some stuff that u should have changed atleast one time even two at that milage:
*Vanos oring rebuild(u should relley do this to restore low rpm power)
*Change sparkplugs
*Replace that crappy K&N filter and put in the original with new filter, yes the sound is not the same but for the peace of your mind u know your engine will run alot cleaner.
*Change oil with a good LL01 BMW oil and repalce filter
*Repalce vcg and clean your engine
*Replace belts and pulleys with new ones
*Use some engine cleaner and rev the engine abit more, it is designed to red line so red line it!
AquaRelliux is offline   Reply With Quote
Old 04-12-2013, 04:09 AM   #5
NumbaOneNewb
My Ride: 2003 330CI Silver
Also, you are using a human that's inputting a command into a device that at that time could have also lagged as well. Unless your friend jumped the gun in anticipation that you were going to take off or was some sort of a psychic, more than likely, his initiation of the timer also added time to your 0-100. The factory stats I'm sure didn't include a passenger in the car either. Tell his ass to get out of the car next time. Better yet, he has an iphone you say? okay. Buy a bluetooth Obd2 adapter. get an app called Torque pro. once you get it all setup, as soon as you step on the throttle from a dead start, the car will automatically calculate it for you, eliminating human error. on top of that, it'll measure and record other info, such as max HP reached during that test (or during normal drive, it'll keep track of the hp that you are currently using, as well as the max you've reached during that drive until you shut your car off) and just all these different parameters. if you check my profile, in my photo album, I actually installed a double din deck capable of mirroring anything that's on the screen of my phone exactly as it onto my double din, even allowing me to use the double din touch screen to control the phone itself as if it was my phone. you can have gauges monitoring all different kinds of stats. best thing? its free.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-13-2013, 07:55 AM   #6
FCUK3R
My Ride: 2000 330ci
Wow that's awesome will have a look for an ObD2 adapter on ebay. An the gauges you are talking about is that the same app that records times and hp?? Will definitely get it cannot believe the technology available on iPhones!
Old 04-13-2013, 08:02 AM   #7
FCUK3R
My Ride: 2000 330ci
*Change sparkplugs
Thanks for that man will have a look at doing the vanos rebuild but sounds expensive but if it restores bottom end then that's probably what it needs. No I never drive it hard intill it's warmed up so it when it's warm that this happens. Also on a side note my gear shifts are a bit jerky when cold...normal?
Ill probably get rid if that k&n **** too coz it jst takes in hot air lol but yea I will try look ino all that **** just don't have a lot of money ATM. Oh and what's vcg?
Old 04-13-2013, 08:25 AM   #8
diM3tri
My Ride: 330ci + stg2 Scoobie
VCG is valve cover gasket. Very easy job that costs about 30 bucks. Look it up on the forums, there's a bunch of good DIY's
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 04-13-2013, 09:11 AM   #9
NumbaOneNewb
Yeah they have the app for both android and iPhone. I'd recommend looking up their list of compatible Bluetooth adapters. I bought a generic cheap Chinese one for $15.
Yes it's the same one that can monitor quarter mile, 0-60, 0-100. It also has a check engine scan, you can use it as a heads up display. I used to do that but when I replaced windshield, it then caused the double ghost images. I've found that adding a reflective screen protector to your phone will help if not eliminate that
Sent from my SPH-L710 using Bimmer App
Old 04-14-2013, 05:52 AM   #10
FCUK3R
My Ride: 2000 330ci
Ok yep that's been done already. Cleaned and oiled the k&n and noticed big improvement. A lot more punchy and can cruise up some hills in 5th where I coodnt before. Fuel consumption also dropped a bit
Old 04-14-2013, 05:53 AM   #11
FCUK3R
My Ride: 2000 330ci
Ok sounds good can't wait
Old 04-14-2013, 09:24 AM   #12
Hollywood516
My Ride: 02 330i
I love my torque pro... it also does more advanced stuff such as fuel trims, long term fuel trims , O2 voltage, how much fuel is left in the tank ,average mpgs,ect,ect.
Hollywood516 is offline   Reply With Quote
Old 04-14-2013, 06:17 PM   #13
lszlszx
My Ride: 1.8T, XC70
Did you do the test in steptronic mode, beause in D they start in 2nd.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-14-2013, 11:18 PM   #14
NumbaOneNewb
And on top of sport mode did you floor it until yiu felt the clicking in the pedal?
Old 04-14-2013, 11:31 PM   #15
tock172
My Ride: '12 135i Dinan S2
I believe it's 7 for autos and 6.5 for manuals, just for reference.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 04-15-2013, 06:16 AM   #16
FCUK3R
My Ride: 2000 330ci
I floored it until I felt some resistance (before the click for the kick down). I try avoid that button coz it irritates me when I hit it in manual mode and it downshifts for me. But I will try just leave it in sport mode and completely hit the gas, kickdown button and everything tomoro night and see what happens. I could not find torque pro for iPhone but downloaded something similar called engine link...still waiting for adapter to come. It disent have the accel timer tho so I downloaded something for free called bmw m power meter which does it based on GPS so will try it tomoz. Otherwise will download the REV app which has everything but costs $42...
Old 04-19-2013, 06:08 PM   #17
FCUK3R
My Ride: 2000 330ci
So managed a 7.2 in sport mode not manual and with a bit of a launch off the brake. Yayy. feels like its got abit more in it especially if i replace the vanos o rings like someone suggested earlier Amazing how these cars still run like new even with high mileage provided they looked after
Old 04-19-2013, 07:22 PM   #18
NumbaOneNewb
So did you use an app, phone, and obd2 adapter to measure this?
Old 04-19-2013, 09:17 PM   #19
FCUK3R
My Ride: 2000 330ci
Still waiting for my adapter to come but for the meantime I used an app based on GPS called BMW m power meter which seems accurate as long as u r on flat ground and the phone is secure but when the adapter comes I will try it again on the REV app. The car definitely felt a lot quicker after cleaning the air filter and launching it made a difference too. Also before when I used it in manual mode I may have been shifting a tad early like around 6250 instead of 6500
330ci, acceleration, slow, sluggish, steptronic
