Sponsored by The Tire Rack
Old 04-12-2013, 08:58 AM   #1
Rahsblk330i
My Ride: 328i
Tire pressure for 05 330i zhp ? HELP
I have conti 255/35zr 18 tires the tire pressure on the car says 46 front and 49 rear is that correct for this style tire?
E90BAI!
Rahsblk330i is offline   Reply With Quote
Old 04-12-2013, 09:09 AM   #2
NumbaOneNewb
My Ride: 2003 330CI Silver
where on the car are you getting this info
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-12-2013, 09:15 AM   #3
shanneba
My Ride: 2003 330Ci
This is what I see in my 2003 owners manual:
Tire size: normal / Max load
Front-225/40 ZR 18 32 / 39
Rear -255/35 ZR 18 38 / 46
Looks like you can download the 2005 330i owners manual from BMW USA:
http://www.bmwusa.com/Standard/Conte...modelcode=0542
It lists slightly different pressures and includes pressures for speeds > 100 MPH
Also if your tires are SL (standard Load) or XL (extra load) will effect the max load tire pressure the tire supports. (not the max inflation pressure on the side of the tire)
http://www.tirerack.com/tires/tirete...jsp?techid=196
Join BMWCCA
Old 04-12-2013, 09:22 AM   #4
zanga254
My Ride: 2002 325xi ZPP
I think you're looking at maximum values for inflation. I would stick with the values outlined in the manual and adjust accordingly using the chalk method for track days.
EDIT: I like what I saw here so i'm adding it to my post. http://www.e90post.com/forums/showthread.php?t=670476.
He outlines the chalk method very well in the thread.
Originally Posted by djlinux64 View Post
I am content with cruising at only 130 mph.
zanga254 is offline   Reply With Quote
Old 04-12-2013, 02:06 PM   #5
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
A good DD cold tire compromise is 35 lbs which I have not had any problems with.
Jim Murphy is offline   Reply With Quote
Old 04-12-2013, 07:43 PM   #6
Alex323Ci
My Ride: M3 & 323Ci (sold)
tire pressure from BMW is known to be listed as higher than most use.
Old 04-12-2013, 10:55 PM   #7
nlav26
My Ride: 2001 330i
46 and 49 are definitely high. I run 33 front and 38 rear.
stahlgrau ~ tannin
nlav26 is offline   Reply With Quote
Old 04-13-2013, 10:28 AM   #8
Rahsblk330i
My Ride: 328i
Koo thanks
Old 04-13-2013, 11:09 AM   #9
NumbaOneNewb
I runn35/38
Old 04-13-2013, 09:34 PM   #10
Dave1027
My Ride: '06 IR zhp coupe
I run 33 front and rear. Seems to hit the sweet spot.
Old 04-15-2013, 02:40 PM   #11
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
40+ is too high. 33 and 38 would be better options for you.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
