Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 04-12-2013, 06:03 PM   #1
e46318tise
My Ride: e46 38ti se compact
Fuel guage level stuck on empty even with full tank...HELP try everythings!
Hi everyones i am new on this forum, just bough a 52 reg e46 compact 318ti se.
The fuel guage does not moved away from EMPTY, is stuck there.
I have checked a few things already but no joys, anyway these are some of the checked carrys out:
*connector at fuel pump all ok.
*fuse check in glove compartment all ok.
*obc cluster check all the guages moves forward and back include the fuel guage.
*fill the tank to a full tank.
*replaced the fuel pump but its still the same as.
ANY OTHER IDEAS WILL GIVE IT A TRY SO PLEASE HELP!!!!!!!!!!!!!!
LOVE THE CAR BUT HATE THIS ISSUE
e46318tise is offline   Reply With Quote
Old 04-12-2013, 06:36 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
Search: Fuel sending unit.
If you have verified that the gauge works.
(OBD hidden functions Menu 21)
Then I would guess sending unit.
Have you replaced the fuel pump, or know that it has been replaced?
You might consider this a polite warning from your car, to replace your fuel pump.
Old 04-12-2013, 07:08 PM   #3
e46318tise
yeah pal did replaced the fuel pump but still its the same result
Old 04-12-2013, 07:15 PM   #4
e46318tise
i dont have the obd tool, just done the obc test with the guage that all and they all moved forward and back,included the fuel pump
Old 12-29-2013, 01:56 PM   #5
evelynsmee
My Ride: 325ti
Not sure how useful this will be, but I had a similar issue recently, the gauge moved but what it thought was quarter of a tank was actually empty (discovered this at 60mph on a dark, country road, fu BMW, thank you Wiltshire police lol! ).
Anyway, on my 03 325ti, they replaced a sensor thing and it works fine now. It waasss *goes to find paperwork*... "n/s fuel level sender unit"
evelynsmee is offline   Reply With Quote
