Sponsored by BimmerWorld
Old 04-13-2013, 07:11 AM   #1
Jat007
My Ride: 99' 323i
Thumping noise in the rear of the car....
Hello,
I am hearing this light thumping noise in the rear of my 00' 323i e46 whenever I starting to move from a dead stop and whenever I accelerate when I am almost at a dead stop. Could it be the rear bushing of some sort?? Other than that, the car drives straight and normal.
Thank you in advance.
Jay
Jat007 is offline   Reply With Quote
Old 04-13-2013, 07:34 AM   #2
certify
My Ride: 328i 2000
I had a slight thumping sound when stopping the car. But for my case its intermitent. I changed the gearbox mount, rear diff mount but the problem still persist. Hope you have better luck than me, trying to solve this.
certify is offline   Reply With Quote
Old 04-13-2013, 08:31 AM   #3
diM3tri
My Ride: 330ci + stg2 Scoobie
Check your rear subframe. 323's and 328's are prone to subframe cracking
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 04-13-2013, 09:06 AM   #4
NumbaOneNewb
My Ride: 2003 330CI Silver
Dragging a corpse?
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-13-2013, 05:38 PM   #5
Jat007
My Ride: 99' 323i
Had the rear subframe checked today and all looks good. No, I and not dragging any corpse for quite sometime now...
Old 04-18-2013, 07:11 PM   #6
2esalinas
My Ride: 330xi
I'm having the same problem I've been thinking its the rear differential bushing but as well maybe my transmission? Any advise?
2esalinas is offline   Reply With Quote
Old 04-18-2013, 07:21 PM   #7
sunnyjay
My Ride: 01 330i
In my case it was my diff bushings.
sunnyjay is offline   Reply With Quote
Old 04-18-2013, 07:29 PM   #8
dre8119
My Ride: destroys my wallet
Could be differential mounts. I had the same problem
dre8119 is offline   Reply With Quote
Old 04-18-2013, 10:45 PM   #9
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
when we say subframe, we actually mean trunk floor pan where subframe mounts onto. Fine metal fatiguing occurs, often on the left side. You cannot see it unless you cut a hole in your trunk or scrape off tar insulation.
Could also be the flex coupling in the drive shaft or some random bushing.
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 04-19-2013, 08:54 AM   #10
Jat007
My Ride: 99' 323i
From all the research on this site and the .NET, looks like you will have to drop the Differential to replace these bushings. There are tools that can help you to make the job easier. The total investment of these tools are about $250... You can also rent them as well.
This will be the summer project for me.
Old 04-01-2014, 09:40 AM   #11
RonnieE46
My Ride: E46 320ci cab
Diff problem
If you can get the car on a ramp turn the prop shaft manually and see if it turns sooner than the wheels start spinning. I say this because on mine the prop turns about a quarter turn before the diff kicks the wheels into motion. If this happens you need to replace the diff. I have a 320 cab and I have that thumping sound but after checking all my bushes I turned the prop and discovered the issue. Hope this helps!!! Diffs are available on eBay from 100-200 depending on mileage and condition.
RonnieE46 is offline   Reply With Quote
Old 04-01-2014, 11:44 AM   #12
AndrewReaganM
My Ride: 02' 325xi OrientBlue
Could it be the center carrier bearing & mount for the driveshaft? I had a similar sound but it happened only at certain speeds while under moderate to hard acceleration. The rubber the held the bearing to the mount was completely torn apart and the driveshaft was just wobbling around in there.
AndrewReaganM is offline   Reply With Quote
