Old 04-14-2013, 11:14 AM   #1
zooswanko
My Ride: 328i
Send a message via AIM to zooswanko
reset oil service light with pa soft?
just got my pa soft scanner and i love it. used it to code my alarm, shut off my airbag light, and remote windows up.
I want to reset the yellow oil service light that comes on for a few seconds after starting the car but im not sure exactly what to do in the software. I searched and couldnt find exactly how. I went to IKE and clicked "oil service reset" but it didnt do the trick (light still comes on). Can anybody give me a detailed walk through on how to reset the oil light with pa soft? Much thanks
zooswanko is offline   Reply With Quote
Old 04-14-2013, 08:44 PM   #2
haurelio
My Ride: 2001 bmw 325i
the light will be coming on regardless , unless you replaced the oil level sender.
Contact me if you need to unlock your phone.
Also can code your car
Old 04-14-2013, 08:52 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
The oil light indicates oil level. If your oil level is ok, then the sensor is bad. Someone was selling the sensor for about $40. Used to be $100.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-14-2013, 09:20 PM   #4
zooswanko
My Ride: 328i
i dont think its the low oil light. its the yellow oil light that comes on, above the speedometer in the cluster. just turns on for a few seconds then goes off
Old 04-14-2013, 09:33 PM   #5
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
It is the oil level light. Check your oil, if it is not missing oil then it is the oil level sensor.
Sent from my ADR6425LVW using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 04-14-2013, 09:51 PM   #6
BMWCaptain
Your oil pressure light (red when low pressure) doubles as a low oil level indicator when your car first starts. Your red light will shine yellow for about 12 seconds when first driving to indicate low oil level.
Is it the oil pressure light your are referring to, or something else on the dash?
BMWCaptainE46.com
Old 04-14-2013, 10:50 PM   #7
zooswanko
My Ride: 328i
oil level i check every couple weeks and is fine. its just the yellow for like 5 seconds after starting. guess its a bad oil level sensor. I wonder if i can bypass it like i did for the brake pad wear sensor cause i dont need a light to tell me my oil is low.
Old 04-27-2013, 01:27 PM   #8
dvd64
My Ride: bmw e46 CI
IKE coding :
dvd64 is offline   Reply With Quote
Old 04-27-2013, 02:18 PM   #9
BMWCaptain
Forgot about that setting. Yes, just unchecked it in the Settings.
BMWCaptainE46.com
Old 04-27-2013, 02:33 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Buy a Hella sensor and replace your failed unit during your next oil change.
Old 04-27-2013, 04:51 PM   #11
BMWCaptain
No! It's a waste to spend $150 for w sensor we don't use.
BMWCaptainE46.com
Old 04-27-2013, 04:52 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
I don't see how spending $90to fix a car is worthless..
Old 04-27-2013, 06:44 PM   #13
zooswanko
My Ride: 328i
sweeeeet! soooo gonna uncheck that box
Old 04-27-2013, 10:17 PM   #14
haurelio
I agree with you , but i wouldnt turn that setting off just in case
Old 04-27-2013, 10:28 PM   #15
BMWCaptain
If I have to explain it to you, you probably won't understand.
BMWCaptainE46.com
Old 04-27-2013, 11:32 PM   #16
zooswanko
My Ride: 328i
That sensor is for people who don't know have any knowledge of cars or are careless
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 04-28-2013, 02:06 PM   #17
dvd64
My Ride: bmw e46 CI
orange warning will light up to alert low oil after the car is turned off. It will not alert while driving. The only oil light that would turn on while driving is the red oil light, and that is alerting you there is low oil pressure, and to shut down the engine immediately.
i have disabled my orange oil level , no problem with that .
I have a dipstick, I don't need another light - especially a completely unreliable one
And red pressure light work the same and that one it' s more important then the level sensor (If you suddenly lost a lot of oil your oil pressure light would come on. )
Old 04-28-2013, 04:33 PM   #18
zooswanko
My Ride: 328i
Old 04-28-2013, 04:34 PM   #19
zooswanko
My Ride: 328i
Anybody know if theres a way to shut off automatic climate control after turning the key?
