Old 04-14-2013, 03:03 PM   #1
ahwest
My Ride: E46 M3
headlight question
I just picked up a 01 M3... I was checking the passenger side bulb... i was told that the bulb blew so I swapped it to the driver to verify... the bulb is ok so I think the ballast is shot; however I realized that it has two different headlight setup just now... passenger side is bixenon driver side is regular xenon? can i just get a bixenon driver side headlight unit and a working ballast for the passenger side? (regular ballast ok?) I just want to match them on both side bixenon...
ahwest is offline   Reply With Quote
Old 04-14-2013, 03:06 PM   #2
sillieidiot
My Ride: '06 AW 330ci
yes you can. but your year didn't come with bixenons stock. it was the single xenon. you can't even use the bixenon function.
Old 04-14-2013, 03:42 PM   #3
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Wow, even the halogen bowls are different. I would check everything else out about the car to see if anything else is funky.
HacksawMark is offline   Reply With Quote
Old 04-14-2013, 05:48 PM   #4
ahwest
My Ride: E46 M3
i guess my question is the bixenon ballast different than regular xenon ballast?
Old 04-15-2013, 02:44 AM   #5
sillieidiot
yes it is. but it sounds to me from what you said is that you are planning to buy a bixenon driver's side unit (which includes the ballast ignitor). and you need to replace the passenger side ballast which would also use the bixenon ballast. you can't swap the old xenon headlight (which is currently in the working headlight) one over as it uses different number of pins.
Old 04-15-2013, 10:06 PM   #6
ahwest
My Ride: E46 M3
sillieidiot, so in order to match both side bixenon unit and working HID, seems like aftermarket HID kit is the only way to go?
Old 04-15-2013, 10:41 PM   #7
sillieidiot
no, but it's the cheapest way.
but you just need to buy 1 driver's bixenon headlight unit (that comes with the ballast/ignitor). then you need 1 ballast for the bixenon unit that you currently have that isn't working.
you need to buy that ballast regardless for the non working side.
Old 04-16-2013, 12:28 PM   #8
ahwest
My Ride: E46 M3
I just found a set of used D1S hid kit that was used on my S4 before... I have searched on the forum and I get different information on whether you can fit D1S bulb into the stock housing... can someone please confirm this please? I would like to just get a driver side bixenon headlight and then put on my used D1S hid kit.
Old 04-16-2013, 01:58 PM   #9
haurelio
My Ride: 2001 bmw 325i
they wont fit on d2s sockets, at least the one i had didn't
Contact me if you need to unlock your phone.
Also can code your car
Old 04-16-2013, 02:27 PM   #10
sillieidiot
it's not going to work.
Old 04-17-2013, 03:08 PM   #11
ahwest
My Ride: E46 M3
another headlight related question.... are the corner lens for bixenon headlight different from the single xenon headlight? because the passenger corner len seems not aligning properly with the bixenon headlight... if so is there a specific corner lens for the bixenon headlight?
thanks again!
Old 04-17-2013, 07:00 PM   #12
haurelio
corners are based on cars model, not on xenon or bixenon differences. they are either not position correctly or they are cheap aftermarket ones.
Old 04-18-2013, 05:08 AM   #13
sillieidiot
thanks again!
yeah, slightly. the bixenon units use screw in corners. while the single xenon uses push in. obviously, screw in corners are better.
Old 04-18-2013, 10:41 AM   #14
ahwest
My Ride: E46 M3
got it, thanks guys!
