E46 Convertible
Old 04-14-2013, 05:33 PM   #1
taylor192
My Ride: 2003.5 M3
Need pictures of the top frame without the fabric!
Does anyone have pictures of the convertible top frame without the outer fabric installed. This is the best I could find online. Looking for a higher quality photo of the plastic cover circled in red. This cover protects the hydraulic lines as they turn from the tension bar to go down the "c-pillar" part of the frame. I need to determine how to loosen this cover to route the hydraulic lines.
From the photo it looks like it is riveted on... which would suck.
Also, how is the fabric top attached to this plastic cover? I cannot get my fingers between the fabric and plastic cover. I assume the fabric is glued/taped at this location since I don't see any connections at that location on replacement fabric tops. Maybe some heat will loosen it...
