Old 04-15-2013, 05:44 PM   #21
wallyworld
My Ride: 2003 325i 4dr sedan
the corners are always on in full on position? i guess i never noticed.
wallyworld is offline   Reply With Quote
Old 04-15-2013, 05:49 PM   #22
NumbaOneNewb
My Ride: 2003 330CI Silver
I believe that's correct. Now regarding coding. Whether you code the car for bixenon or not, your hid should come on. The difference is if coded add bixenon, you wouldn't need capacitors to stop the flickering because the car understands that. Seeing 35watt hids is totally normal. Not coding it will cause flickering but can be solved with capacitors. Now what light cancel error are you asking about
And the corners, US style corners will have them on with light switch on position 1 and 2. Euro style will not have them on except for signaling, which is how I have mine.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-15-2013, 07:28 PM   #23
wallyworld
i was going to get warning cancellers/anti-flicker to solve my problem. This would work wouldnt it? how do I get euro styling corners so they arent on all the time? They are a very ugly watered down amber.
Old 04-15-2013, 07:30 PM   #24
sillieidiot
My Ride: '06 AW 330ci
you need to get it reprogrammed by a fanatic in your area with ncs expert experience. if you're going to do that, then no point in getting the warning cancellers since you can just code for xenons as well (probably bixenons cause you have an 03). otherwise, just live with it. replace the bulbs, it sounds like you have clear bulbs in the clear corners. use an amber bulb or LEDs or something.
Old 04-15-2013, 07:45 PM   #25
wallyworld
ok im still a bit confused. I ordered warning cancellers/anti flicker. I just cancelled them because all I need is coding? So by coding the car will deliver 35w to the ballasts instead of the OEM 55w? Everything will work great? Im not doubting whatsoever, Im just new to all this and would like to learn and understand better.
Old 04-15-2013, 07:50 PM   #26
NumbaOneNewb
First off, do you know how to code? No? Well the most simplest way to code your hids is with a thing called pa soft bmw scanner v1.4. I also recommend it for reading check engine lights. It will not code your corners to euro corners however. That requires much more advanced knowledge. The pa soft can be bought for under $30
Old 04-15-2013, 07:54 PM   #27
NumbaOneNewb
Stay with that. You can also activate the oem alarm that all US bmws have built already in it, make your lights flashduring llock unlock roll windows up with remote. If you feel more comfortable move to more advanced stuff
Word of caution. If you dont know what it does, Google it or ask. You may regret your actions and all the crying won't save your car
Old 04-15-2013, 08:02 PM   #28
wallyworld
yea fortunately i found another fanatic who will do it for free. so I will get OEM alarm coded, windows to go up with remote, euro corners.
So coding for xenon "in theory" will fix this projector/HID issue im having?
Old 04-15-2013, 08:03 PM   #29
NumbaOneNewb
In fact, a member had lost all remote functions on both his key, couldn't reinitialized them, and couldn't start car with one key. I was able to get the one key to start his car again but still lost all remote functions. I probably could have helped if i was there but unfortunately I couldn't.
Old 04-15-2013, 08:04 PM   #30
NumbaOneNewb
Not in theory, it will
Old 04-15-2013, 08:24 PM   #31
sillieidiot
but you may or may not lose your highs. if that guy is experienced enough, he'll be able to keep the highs for you too.
Old 04-15-2013, 09:45 PM   #32
NumbaOneNewb
Experienced or not you will lose your highs unless you retro bixenons. Only thing I can think of the most convenient is if you don't use your fogs, you can use them as a way to power the high beams
Old 04-15-2013, 09:54 PM   #33
wallyworld
if I got the wire harness would this make the xenons work and high beams work too?
I'd like all my lights to work.
Old 04-15-2013, 11:03 PM   #34
sillieidiot
yes, if you only do add the bixenon option. you have to do a little more programming to get the highs to work as well.
Old 04-15-2013, 11:11 PM   #35
sillieidiot
you won't need a wiring harness. and it won't do anything btw lol anyways, just ask the fanatic that is doing the coding for you. if he is using NCS expert, he should be able to code it so that both the lows and highs work. coding for xenons (or bixenons) will get rid of the flickering as i stated.
don't listen NumbaOneNewb. although his comments are somewhat accurate, he's not reading or doesn't understand what we're trying to accomplish. if anything, he's making you more confused for no reason.
Old 04-15-2013, 11:20 PM   #36
sillieidiot
just to clear this up. you can't code for euro corners period with that program. so even if you have advanced knowledge of that program it's not going to help you. you need another more advanced program. hence why i told him he needs to find someone that knows how to use NCS. which he already found. stop wasting his time and confusing him more.
when you code for xenons/bixenons, it turns off the cold checks. so you don't have headlight warnings which causes the flickering. on some cars, if you don't code, the headlights don't come on at all. so you have to get this done.
the difference is, if you code for bixenons, you will lose your inner high beams. that is because OEM bixenon units, use a different plug that activates a shutter in the xenon low beams for the high beams. if it's coded for xenons, the function stays the same.
however, you can only code for regular xenons for cars up to mid 02. since he has an 03, it will only show the bixenon option, hence losing his highs. but you can also program it to keep the highs (another european option). that's only if the coder knows how to do it. hence why i told him to ask the coder.
again, why are you making it hard for him? he's not doing it. and don't spread false information. THERE ARE NO US BMWS THAT COME WITH THE ALARM STANDARD. it was an option. however, they are all prewired for it. you can program the car to blink for locking/unlocking and for the clown nose to blink when locked. but there is no chirp, nor is there an alarm.
Old 04-16-2013, 07:11 PM   #37
wallyworld
k im going to code but I want to make sure i have everything wired right first. here are some stock pictures which show how I connected everything.
as for corner lights, im still on the fence on going to euros (if the coder can do that ) or getting some nice white bulbs? input would be appreciated.
ID:	500855   Click image for larger version
Old 04-16-2013, 08:42 PM   #38
wallyworld
pics updated
Old 04-17-2013, 12:29 AM   #39
sillieidiot
yes the wiring is correct. as for the corners, it's whatever you like. technically it's illegal in the US not to have them on. I would just use an LED amber bulb or a white LED to try to match the angel eyes.
Old 04-17-2013, 07:28 AM   #40
wallyworld
any place i could possibly get the corners bulbs locally?
