Sponsored by BimmerWorld
Old 04-15-2013, 08:47 AM   #1
Jat007
My Ride: 99' 323i
Front Struts for e46 Questions
My 99' 323i e46 sedan will need front Struts soon. What do experts on this site recommend? I am not taking the car to the track or anything like that... I just want to restore the ride like when it was 100k mile ago... I am also in school right now so, budget is also a concerns of mine.
Would you recommend struts that are sold on Fleasbay? Some do have lifetime warranty on them...
Please let me know what would you buy and keep budget in mind as well.
Thanks!
Jat007 is offline   Reply With Quote
Old 04-15-2013, 08:51 AM   #2
NumbaOneNewb
My Ride: 2003 330CI Silver
yes. since its not a component related to the reliability of your engine running nor its an electrical sensor that is super sensitive and requires OEM parts, I'd go with anything, really. remember, you get what you pay for. so if you spend less now, expect early replacement, unlike oem which can hold up to 100,000 miles.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-15-2013, 08:57 AM   #3
Guest021715
Account closed.
Take one of each and call me in the morning:
http://www.fcpeuro.com/products/bmw-...-31316750792my
http://www.fcpeuro.com/products/bmw-...-31316750791my
Old 04-15-2013, 09:25 AM   #4
My Ride: Lexus
If shocks are original, needs those too.
Old 04-15-2013, 09:56 AM   #5
GSherbs
My Ride: 2002 330 xi
Just an FYI - replacing front struts alone will not meet your expectations.
I understand that you are on a budget but to make the ride feel like it did when it was brand new would require replacing struts, shocks, springs, mounts, bushings, etc...
Struts, shocks, & springs on all four corners will go a long way though. I wouldn't do fronts only - my concern would be potential handling problems (more so in emergency maneuvering situations than typical daily driving).
GSherbs is offline   Reply With Quote
Old 04-15-2013, 10:03 AM   #6
hitmanre
My Ride: 2000 BMW 328i
I got Monroe shocks and struts and it is def better than blown oem.
hitmanre is offline   Reply With Quote
Old 04-15-2013, 10:08 AM   #7
taveet330i
My Ride: Jet Black 2002 330i
For the OEM style ride the best is sachs. Its the direct OE replacement. The PO installed these on my car but they do wear out quickly. Look into bilsteins. I have rear shocks by them and drove a friends e46 with bilstein all around and it drives amazing
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 04-15-2013, 10:54 AM   #8
NumbaOneNewb
I replaced my rears with Sachs too. They go out quick? Really? Are you lowered? Mine feel good still, I think. I haven't done the front yet
Old 04-15-2013, 11:46 AM   #9
Jat007
My Ride: 99' 323i
The fronts are original struts as far as I can tell. The rear are KYB's as far as I know, KBYs were not the oem stock rear shocks. However, one of the rear springs cracked/broke at the bottom of the coil... So, I will be doing all 4 corners.. I have about 174K on the car at the moment and I don't want to spend a whole lot... This is my daily driver for roughly about 10 miles a day and I'm not hard on my car at all...
Thanks everyone for your input!!
Old 04-15-2013, 12:56 PM   #10
Jat007
My Ride: 99' 323i
I am thinking that I have the standard suspension - how can I tell?
Help!
Thanks.
Old 04-15-2013, 01:10 PM   #11
celt
My Ride: '02 325i
If struts are original you may be able locate a part number on one of them which would indicate whether you have sport suspension or not.
celt is offline   Reply With Quote
Old 04-15-2013, 01:13 PM   #12
dancmos
My Ride: BMW 323i
I just put Koni Yellow Sports on my '00 323i. The problem is they weren't cheap and a DIY on struts is tough so I paid a guy to do them. Shocks are easy. You'll also need an alignment. Don't cheap out on this. Struts and suspension bits are super important.
dancmos is offline   Reply With Quote
Old 04-15-2013, 01:19 PM   #13
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You can get Monroe strut and shocks at AdvanceAutoParts. They have a lifetime warranty and are offering a rebate right now until April 30,2013.
If you are doing shocks, and struts, then replace mounts as well.
If you are a student on a budget, you can get all 4 corners for about $200 with discounts and rebates.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-15-2013, 01:57 PM   #14
Jat007
My Ride: 99' 323i
I've used Monroe before on my other cars and I was very surprised how well they performed... Tell will tell as I only have them in for 10K miles on a standard sedan. As one member "Stiggles" point it out, the Meyle front strut for $81.99 isn't too bad if you're doing just the strut. You're are right though, I will need to do the coil springs and the strut mounts along with a new struts.
As for the wheel alignment, I did purchased a "lifetime" alignment from Firestone a year ago.. So I am covered there..
If I go with the Monroes, can I use a different brand for the strut mount or I have to use the same brand? Where would you recommend for me to buy the coil spring for the fronts?
Thank you!
Old 04-15-2013, 03:29 PM   #15
taveet330i
Yeah they were replaced at 88k and I have 160k on the clock now and the car is loose and jumping all over the road
[bimmerapp]
_______________
Dedication
Old 04-15-2013, 03:54 PM   #16
Jat007
My Ride: 99' 323i
Taveet 330i Dallas - What do you have on your car now?? Double whammo for me since I ahve low-profile wheels on mine, so she's jumping all over the roads even on flat straight roads (-:
Old 04-15-2013, 04:00 PM   #17
taveet330i
I have sachs front with bilstein rears. Rears have new oem springs. Fronts are springs from 88k along with the sachs shocks. I just prefer the tighter steering response but its a personal thing
[bimmerapp]
_______________
Dedication
Old 04-15-2013, 04:48 PM   #18
BMWCaptain
You don't have to go with the same brand of strut or shock mounts.
If you go with the Monroe from AdvanceAutoParts, you will get new shock washes, and nuts.
BMWCaptainE46.com
Old 04-15-2013, 04:53 PM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
OEM Sachs shocks
Old 04-15-2013, 05:02 PM   #20
Jat007
My Ride: 99' 323i
Ok, I just pulled the trigger by buying all new Coil Springs (Lesjofors) for all 4 corners. I will do some more research on the Struts & Shocks to buy next. I might go with BMWCaptain's recommendation on Monroe.
What would you guys recommend for Strut/Shock mounts?
Thanks guys!!
