Old 04-15-2013, 10:46 AM   #1
DaveA
My Ride: 330d Sport Touring
OBD2 Port Issues - I think!
HI there, I'm new on here and have a problem with my E46 330d Sport Auto that I'm really now struggling with. I bought the car with the ABS light on. Other than that, and the cigarette lighter not working, the car is spot on and everything works fine. To address the issue of the ABS light, I thought I'd get some software, so having done some research, I bought the BM Technic stuff which I am impressed by. However, I tried to plug it into my car, and it doesn't work! I therefore tested it on a mates 320d and it runs just fine... Having done some research, it appears as though my K Bus may be not functioning correctly. I've used a multimeter to test the pins on the OBD port. The two power wires both have 12v. There are then two bus lines (I think) which are white with a purple line. One of these I think is for the engine and gearbox, which shows just over 10v and then another which does the ABS and other stuff, shows only 0.13v. I think this may be my problem, but surely if this is a bus line, and is down, I would see more problems with the car??? I don't know where to go now. I seem to get pointed to the X10116 connector to test the modules, but I'm not sure how to do this. Any ideas from anyone before I throw in the towel and take it to a garage...
DaveA is offline   Reply With Quote
Old 04-15-2013, 10:18 PM   #2
lszlszx
My Ride: 1.8T, XC70
If it was a K-bus problem, there would be other symptoms as well.
However it may be a D-bus problem, because the SRS, OBDII connector and the round connector under the hood that the older models have are connected. Have you checked the fuses?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-16-2013, 12:55 AM   #3
DaveA
Yes all fuses are fine. My car is a 2003 so there is no connector under the bonnet (hood)...
Old 04-16-2013, 04:28 AM   #4
DaveA
Thanks for that point about D bus. I've done a bit more research and what you say about everything else working hence the K bus being ok makes a lot of sense. Any ideas how I fault find on the D bus then?
