Sponsored by BAVSOUND
Old 07-14-2003, 11:10 PM   #1
XcvX
My Ride: 1999 328i
Send a message via AIM to XcvX
People with Component Speakers...
Where did you mount your tweeters? I was thinking the spot in the middle of the door would be better. TIA
SWED
XcvX is offline   Reply With Quote
Old 07-15-2003, 12:56 AM   #2
dt32569
My Ride: 330Ci
Speakers
I mounted mine in the stock locations. If you set the Xover point at about 200 you get good imaging. When you lower it it tends to blur and pull toward the driver. So....there is some info on that setup.
I thought about mounting them in the middle of the door - lemme know how it turns out. Might help your imaging.
dt32569 is offline   Reply With Quote
Old 07-15-2003, 02:25 PM   #3
Cheburashka
My Ride: '99 328i
I used the stock locations. A little more work to get to than the mid-door solution. They are picking up an electrical/mechanical noise (not a hiss) that I did not hear when I had the OEs on the same setup.
Improving with Age!
Cheburashka is offline   Reply With Quote
Old 07-15-2003, 02:51 PM   #4
SST
My Ride: 325i
I mounted in the stock location. I simply pushed the tweeter body into the foam piece that goes in the stock tweeter location. Perfect fit for a 1"
tweeter. If your tweeter is smaller you can simply tape it in place or epoxy to the foam. The tweeters don't move at all.
TT
SST is offline   Reply With Quote
Old 07-15-2003, 03:10 PM   #5
dt32569
My Ride: 330Ci
You can try this
I took a dremel and opened up the little hole the stock tweeter comes in (in that mid tweeter housing) and slid the tweet in. OR just get a backstrap - bend it up and fasten it that way. Backstraps rule for stuff like that.
Old 07-16-2003, 12:17 PM   #6
daz
My Ride: 2003 Bmw Coupe 330ci
Send a message via AIM to daz
I put my in the stock location as well. Took out OEM tweeters. Used a dremel on the tweeter harnes to make it a little bigger then used epoxy on the new tweeters. Fit well. The for better imaging I set the x-over on the componets tweeter selection to + 3db to get a better imaging...
daz is offline   Reply With Quote
Old 07-16-2003, 06:05 PM   #7
SST
My Ride: 325i
Daz,
You have Audiobahn ABC5002 components?
Is so, did your manual tell you that you had tweeter adjustments?
TT
