Old 04-15-2013, 08:52 PM   #1
412bmw
My Ride: 01' 330i 03' M3 alpw
Helppp!!Alternator not charging
I bought a refurbished alternator few weeks back all the sudden it won't charge the battery. I checked the amps on it my meter was reading 12 and should be 14-16amps, also I had it bench tested and it checked out ok
Any thoughts on the situation?
412bmw is offline   Reply With Quote
Old 04-15-2013, 09:06 PM   #2
lszlszx
My Ride: 1.8T, XC70
Check for battery voltage at the alternator.
At the big connector there should be voltage at all times.
Pull the electrical plug off the alternator and test for
battery voltage with the ignition on.
If there isn't there is a connection, or wiring issue.
This could've been the problem to begin with, did you
test the old alternator, are you sure it was bad?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-16-2013, 06:19 AM   #3
412bmw
I did not test the old one but when I put the new one on it was working fine till yesterday. I'll check the voltage later today and get back to you .
Old 04-16-2013, 06:57 AM   #4
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
I think you mean volts instead of amps. BMW can put out 120amps at 12volts.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-16-2013, 05:46 PM   #5
412bmw
I do don't no why I said amps
Old 04-16-2013, 06:40 PM   #6
412bmw
I am still getting around 11 volts at the alternator with ignition on or off anything else I can check
Old 04-16-2013, 06:41 PM   #7
412bmw
I cleaned all connections and still getting no charge
Old 04-16-2013, 07:46 PM   #8
BMWCaptain
You will get battery voltage at the terminal if the car is not running. You should get 13.5-14.5v with the engine running. If you are only getting 11v when running then your new alternator is bad.
BMWCaptainE46.com
Old 04-16-2013, 08:01 PM   #9
412bmw
Ok I'm feeling the same way . The refurbished alternator has to bad either the voltage regulator is bad or the whole alternator. When the car is on and I test the the battery it only ready 11 volts and it declines.
Old 04-16-2013, 09:32 PM   #10
lcoleman
My Ride: '79 Massey Ferguson
...refurbished alternator...
Good odds this is the problem. Buy a new, not remanufactured one if you can.
Edit: Does the battery light come on the dash? Seems like there's some exciter circuit or something that needs to be closed for the alternator to come on. The problem may also not have been the alternator to begin with.
Old 04-17-2013, 07:11 AM   #11
412bmw
Yes the battery light does come on
