Wheels and Tires
Old 04-15-2013, 10:42 PM   #1
titan510
My Ride: zhp 6sp, 528iA sp
H&R spacers, wheel locks, and more OEM parts
vGarage Sale
H&R 10mm = .39" - extended bolts included (silver) - SOLD
5/120 bolt pattern; 72.5 center bore
DR type = spacer fits in between the wheel and the hub. Longer wheel bolts are required.
Hubcentric = Yes, this spacer comes with a new hubcentric lip for the wheel to rest on
H&R 12mm = .47" - extended bolts included (sliver) - SOLD
To verify part number: http://www.turnermotorsport.com/BMW-...l-spacers.aspx
RAD wheel locks (all model bmw) - 30 shipped
RAD wheel locks are engineered and manufactured in Germany by a true wheel professional who has worked with some of Germanys largest vehicle manufacturing companies including OEM and aftermarket wheel manufacturers -- you know which ones.
OE fuel filter (e46 3-series) - SOLD
http://www.ecstuning.com/BMW-E46-330...ilter/ES33012/
AB03 Adaptor (post 2000 bmw models) - 40 shipped
Adapts R5/FCX-3 and 'SRS past year 2000.
http://www.peake  photo 293.jpg research.com/products.htm
OEM red/amber/red rear lights - (e46 3-series facelift 2003+) - 50 shipped
OEM amber side markers - 20 shipped
OEM bmw 6 CD changer - 100 shipped
Cylinder cover with gasket ring - 60 shipped
OEM Siemen MAF - 70 shipped
Depo smoke driver side front signal (e46 3 series facelift) - 20 shipped
OEM M3 mirrors (e46 4 door and coupe) - SOLD
OEM M3 mirrors with modified base plate to fit sedans, professionally done by a body shop with fresh new paint
(Sapphireschawarz Black Saphire 475). They have been test fitted and were great fit however as most of you know the 03' uses a ribbon motor which I had so I never got around to retro-fit.
Plugs were cut unfortunately which I didn't care for (original motor has 5 wires) which I'm sure you can either splice your plug to these or use your own motor. One of the mirror does have a tiny brown edge which I'll include as many pictures as possible to show condition.
http://www.rogueengineering.com/mm5/..._Code=E46M3MIR
OEM Bi Xenon driver side (e46 sedan facelift came off a Zhp) - 150 shipped
Everything works - stock DS2 4.3K bulb included, ballast, black inserts, cover could use buffing but not necessary. It does have broken tabs.
OEM BMW bike rack - includes cross bars and 2 bike attachments (will fit e39 and e46) - SOLD
OEM leather case with service manual and etc... - 45 shipped
OEM truck actuator - 35 shipped
I thought mines was broken but when I pulled it off I only had a broken spring - stupid me!
OEM water pump - came off from an e39 - 28 shipped
I was just doing a routine maintenance and did my complete cooling system. Gasket seals were tight, no play anywhere and it has metal blades!!
OEM power steering hoses
Depo LED tail lights - (e39 5 series) 65 shipped
Lights are in working condition - they come with resistors to eliminate bulb out <- those parts along should justify for the asking price. Driver side was hit though - in picture you can see that they have a scuff mark which you can probably buff out as well, however on the inside there is a hairline crack you can epoxy to seal it...
Intravee II with Alpine KC-420i - SOLD
The link below pretty much explains all the function for this unit:
You can control ipod with either your navigational system or from your steering wheel controls - one of the best!
OEM fan aux fan unit (from an 2000 e39) - 75
Motor or a sensor may have issues - it turns sometimes...however parts alone is worth more than that... fan blade, shrouds, and etc..
titan510 is offline   Reply With Quote
Old 04-18-2013, 12:46 PM   #2
titan510
bump
Old 04-19-2013, 11:06 PM   #3
bishoyb
My Ride: BMW 325i
PM'd
Sent from my Galaxy Nexus using Bimmer App
bishoyb is offline   Reply With Quote
Old 04-20-2013, 01:45 PM   #4
glhx
My Ride: 2002 330ci
I would do $20 shipped on the wheel locks
glhx is offline   Reply With Quote
Old 04-21-2013, 06:26 AM   #5
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
Would u do $70 for the 12mm spacers? Where in NorCal, East bay?
STREETFIGHTER50 is offline   Reply With Quote
Old 04-22-2013, 11:45 AM   #6
titan510
bump
Old 04-29-2013, 11:10 PM   #7
titan510
bump - i also have an OEM car cover for e46 $150 shipped firm
it's in excellent condition - used mostly in the garage during the wet season
Old 05-09-2013, 08:37 AM   #8
JOEYB24
My Ride: 2002 325XI
I'LL take the oem bi xenons if you still have them
JOEYB24 is offline   Reply With Quote
h&r spacers, wheel locks
