E46 Convertible
Old 04-16-2013, 10:51 AM   #1
dj_clubber
My Ride: BMW M3 2001 (E46)
BMW M3 E46 2001 Convertible Roof Issue..........
Hi All
Just been kindly pointed into the right direction for my roof issues in this section......
Just an update.
I had a problem with the roof and when I pressed the open button, the amber light would come on and that was it. Nothing else happened.
I got an auto electrician in to have a look and now it is showing a different fault. He checked the fault codes but I am not sure he even understood himself what he was doing.
The problem now is that the roof light is just alternating flashing red now all the time. When I press either open or close, the light steady red now. Is this a new problem?
No windows come down or no action with the roof at all. Just a flashing red light.
Appreciate any advice before I look at popping it into a dealer.
Andrew
dj_clubber is offline   Reply With Quote
Old 04-16-2013, 01:25 PM   #2
taylor192
My Ride: 2003.5 M3
You need a shop that can read the CVM codes. If the light is blinking red then the CVM has a fault code.
Likely it is the broken wire problem in the sticky about diagnosing electrical issues.
Old 04-18-2013, 01:55 AM   #3
dj_clubber
I got it booked into CAYMAN now for diagnosis. Hopefully they can have a crack at it on Sunday.
Old 04-18-2013, 08:51 AM   #4
fmzip
My Ride: '08 328xi / '01 530i
This is likely where the break is:
http://forum.e46fanatics.com/showthread.php?t=790169
fmzip is offline   Reply With Quote
Old 04-19-2013, 01:10 PM   #5
dj_clubber
How do you move the roof to have a look at the problem. I can open the latches by using an allen key but the roof is cant be moved by hand unless there is a way to open it. I tried lifting the back and front together and it is not moving.
Old 04-19-2013, 01:22 PM   #6
cityjohn
My Ride: 2001 M3
^ Once the latches release, there's still more unscrewing to do in order to loosen the frame.
cityjohn is offline   Reply With Quote
Old 04-19-2013, 01:40 PM   #7
taylor192
My Ride: 2003.5 M3
Step 2 in my post explains why: http://www.e46fanatics.com/forum/sho...01&postcount=2
