E46 Convertible
Old 04-16-2013, 04:22 PM   #1
Mr. Din
My Ride: e46 M
Top stuck open, how to manually open the lid?
My top is stuck open, when i press the close button the red light just stays lit. When I press the open button no light comes on. Ive been trying to figure out how to manually open the top lid to try to close the roof manually. Anyone have any ideas how? Ive been searching , reading the manual and nothing help.s
[/URL]
Mr. Din is offline   Reply With Quote
Old 04-16-2013, 04:23 PM   #2
KingBee
My Ride: IR '03 M3
I have no experience regarding the top as I've never owned one, but check your fuses if you haven't already!
AA exhaust, PSS10, TMS sways, 5mm rear spacers, more to come!
KingBee is offline   Reply With Quote
Old 04-16-2013, 06:31 PM   #3
taylor192
My Ride: 2003.5 M3
RTFM: Manual operation of the top is covered in the owner's manual.
Hint: It involves an allen key under the rear seat.
Old 04-16-2013, 07:37 PM   #4
Mr. Din
My Ride: e46 M
I read the manual. Use the hex key . Pressed the button. Nothing . The top lid is still locked.
[/URL]
Old 04-16-2013, 07:46 PM   #5
taylor192
My Ride: 2003.5 M3
Pull the rear seat, pop this cover and ensure the cables are in this position (unlocked). If they are not, push the button and keep turning, or turn the other direction.
Old 04-17-2013, 10:45 AM   #6
Mr. Din
My Ride: e46 M
I can only turn it one direction one click then back the other direction one click.
[/URL]
Old 04-17-2013, 11:25 AM   #7
taylor192
My Ride: 2003.5 M3
You're only turning a few degrees, you need to turn at least 90-180 degrees to unlock it. If the button clicks up push it again and keep turning.
Old 04-17-2013, 04:03 PM   #8
Mr. Din
My Ride: e46 M
finally worked, got the lid open, installed my hardtop installtion kit put the hardtop on for now.
Thanks!
[/URL]
