E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 05-24-2013, 12:49 PM   #41
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
Good point. Looks like this one is recessed a bit, presumably for a reason:
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 05-25-2013, 01:15 PM   #42
garrafa
My Ride: E46 M3 CONV
Originally Posted by taylor192 View Post
I found a post where you're advertising it for $50, why the change of price?
Also, could you post up close pics of the sub with the seat installed. Most that have installed a sub in the ski pass have built a triangular box with the front recessed from the metal so that the sub does not hit the seat or removable section of the seat.
Dear Taylor192,
This looks quite nice, but it will limit you to an 8" sub at most, which is the OEM size as it's within the same boundaries/frame as the OEM sub. With my bracket, you can install up to a 12" sub. It also appears to be not entirely flush with the metal frame. My bracket will not be a problem for rear seats since the whole rear seat backrest is one large piece of foam with the front wrapped in leather. It will flex to accommodate my bracket frame and the deflection required will be negligible to the eye. You can always shave off some of backrest foam to accommodate the frame.
P.S. The rear seats, seat belt hardware and rear headrests weight about 50 lbs! why would you want to carry that around?!
Price went up due to my supplier upping the cost due to low-volume precision cutting these within required tolerances as well as me including the special metric bolts and washers. You can always make an offer for one for less on eBay:
http://www.ebay.com/itm/151051003618...witem=&vxp=mtr
garrafa is offline   Reply With Quote
Old 05-25-2013, 01:18 PM   #43
garrafa
See my prior posts, this BSW will limit you to an 8" sub and much less power for more money and lower quality components... it's all about what you value the most...
Old 05-25-2013, 07:13 PM   #44
dknightd
My Ride: 2002 330 cic
bsw sub is 10". Seems to use decent components. Yes the price includes a decent profit. So but so does your $75 piece of mdf and screws. Don't have either. Neither is ideal IMO, so I'll either do it myself, or, fork out the money. Near as I can tell your surface mounted solution would be easiest if you did not mind a sub rubbing against seats. Like you say - it is all about what you value most.
dknightd is offline   Reply With Quote
Old 05-25-2013, 10:58 PM   #45
taylor192
My Ride: 2003.5 M3
Re: E46 convertible subwoofer MDF bracket 12" 10" 8" Haman Kardon upgrade
That picture is of a 10" or 12" sub, I forget, yet both sizes can easily be run.
Thanks for pointing out the seat has to flex around your design. Not that big a deal, yet important info for those interested.
Sent from my Nexus 7 using BimmerApp mobile app
Old 05-26-2013, 12:05 AM   #46
garrafa
It's a 12" INCHER
Old 05-26-2013, 08:52 AM   #47
garrafa
Few more pics of 3D CAD model:
ID:	507608   Click image for larger version
ID:	507609   Click image for larger version
ID:	507610   Click image for larger version
Old 05-26-2013, 09:29 AM   #48
daniel_f.
My Ride: 330iC
is your sub supposed to be a free-air unit? and if it is, shouldn´t the room behind the sub be completely sealed to the front? i´m no audio expert at all and to be honest i think my harman kardon system is appropiate, but if i would change, i guess i would build something similar to the bsw system, even it only had a 10" sub, which should be more then enough...
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 05-26-2013, 10:00 AM   #49
garrafa
Nope. The whole point of using a free-air unit is that it DOES NOT have to be sealed...
Old 05-27-2013, 11:05 AM   #50
dirty vert
My Ride: 2001 330ci
In a free air setup, if you have more than 1/4" of a gap between the trunk and the cab you will loose db's.. it needs to be tight-no gaps to produce the best sound and punch.
dirty vert is offline   Reply With Quote
Old 05-30-2013, 11:34 AM   #51
garrafa
The manual says nothing about above, they say it is designed for rear of sub facing the trunk of a car.... and in my experience as installed, it is plenty loud, so loud I can only crank it up about 75% before I can't take it any more....
Old 05-30-2013, 11:52 AM   #52
garrafa
Sold first one to Ontario, Canada, woo whoo!! big woop
Old 06-02-2013, 08:50 AM   #53
daniel_f.
My Ride: 330iC
So one more point to go 10" instead of 12" and have it proper mounted inside instead of on top of
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-11-2013, 09:51 AM   #54
TheHulk9er
My Ride: 2000 323ci Convert
A couple of points here. One, the BSW sub has an Aluminum cone (not paper) and at one point was made by a company named Alumapro that made a 1st class sub. Two, in infinite baffle the whole idea behind the baffle is to separate the rear wave from the front wave as the rear wave can cause wave cancellation and affect both the quantity and the quality of the bass. Most subs can be run IB but the best have a Qts in the neighborhood of .707 as this is where the suspension delivers the best compromise between low frequency extension and transient response. The Qts of the speaker indicates the shape of the roll-off. While I applaud the idea here, I would make sure to seal up the baffle, and I would also clean up the area behind the seats so that the suspension of the sub woofer did not come into contact with the seats. I do love the idea of a 12" sub over a 10". I have even considered losing my back seats (I don't need no stinking back seats!) so I could do two 12" subs or IB one 15".
TheHulk9er is offline   Reply With Quote
Old 06-11-2013, 10:06 AM   #55
garrafa
I considered insulating the sub-woofer frame to the car chassis by using 1/4" medium density foam along all the contact areas, but I found that without the foam, the impact of the sub actually travels to my front driver's seat, and I LIKE IT! And since the car is so well built, nothing rattles! (I still can't get over that fact) . It adds to the experience of "feeling" your music, not that a 12" 1400 Peak Watt Sub won't do that for you!
All in all, as I've said before, my setup sounds very good, bass is powerful and clear, all I wanted and even more... When I have the time, I may create an optional "box" to attach to the rear of the sub for those who must have an ported/non-ported enclosure...
Old 02-07-2014, 03:52 AM   #56
BranchTwenty1
My Ride: '04 330Ci Vert 6-Spd
Any luck on that enclosure project, garrafa?
BranchTwenty1 is offline   Reply With Quote
Old 02-07-2014, 07:38 PM   #57
garrafa
Works like a charm, you can buy bracket on eBay.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=151051003618
Old 02-08-2014, 03:02 AM   #58
BranchTwenty1
Thanks, but I wasn't referring to the bracket, but the sealed ENCLOSURE that you said you might start working on. So I was wondering if you had any luck with that project. :-)
Old 02-08-2014, 10:02 AM   #59
garrafa
Not yet, it's on my to do list, will let u know .
Old 02-23-2014, 09:14 AM   #60
ohtaile
My Ride: 2002 BMW 325CI
Do you have any more pics of this install? I am very interested in doing this to my 2002 325CI.
ohtaile is offline   Reply With Quote
