Old 04-17-2013, 12:45 AM   #1
LilFlip#2
My Ride: not a bimmer
Active Auto Generation 6 stage 2 dyno..need input
Hey guys
Just upgraded to the stage 2 generation 6 and I am having some concerns with the Afr
Does anyone think this is fine or too lean.
2005 SMG
Jvt headers
No cats
45,000 miles
2005 IB ZCP - AA 1.5 HKS - Work VSXX - 430 RWHP 91 Octane
LilFlip#2 is offline   Reply With Quote
Old 04-17-2013, 01:50 AM   #2
MotivatedPY
My Ride: 04 M3
Your very brave if u keep your foot in it that lean especially on pump.. Most cars iv been around are in the 11.8-12 range with the exception of a few direct injected cars on e85 that were mid 12s.. Assuming your running meth now?
MotivatedPY is offline   Reply With Quote
Old 04-17-2013, 02:25 AM   #3
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Nearly 14psi?! That's a lot for the stock motor and that's very lean. I wouldn't leave it like that. Looks like the car is pulling timing up top. Ask Specialty Z to get you the graph with 0 smoothing instead of 5.
MSpired is offline   Reply With Quote
Old 04-17-2013, 02:51 AM   #4
TrippinBimmer
My Ride: Just Fast!
Super dooper lean!!!
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 04-17-2013, 07:35 AM   #5
Commanderwiggin
My Ride: 900rwhp Turbo M3
It's really lean...also STD will read higher than the common SAE.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 04-17-2013, 10:06 AM   #6
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Numbers also look pretty low for a stage 2
AMG-ETR is offline   Reply With Quote
Old 04-17-2013, 11:01 AM   #7
LilFlip#2
Does anyone think this is more of a hardware issue vs a tune issue.
Anyone in the San Fernando valley have a INPA that can help me out
Talked to Zak yesterday and he asked me to clear my adaptations one more time before we start messing around with the tune
Old 04-17-2013, 06:17 PM   #8
MSpired
Do you have a boost gauge in the car? What does your vacuum read at idle? Is the kit supposed to be running at 14psi?
Old 04-17-2013, 06:38 PM   #9
Commanderwiggin
Mike that peak is because the throttles closed at the end of the pull.
Old 04-17-2013, 06:53 PM   #10
MSpired
Ah, should have paid closer attention. Still looks to be a bit over 12psi... I think I remember that being normal for this kit?
Old 04-17-2013, 06:57 PM   #11
Commanderwiggin
The problem isn't the boost...it's the tune...or something else fuel related.
Old 04-17-2013, 07:02 PM   #12
MSpired
I don't think so either, but just checking if that is normal, that a lot of boost for a stock motor!
Old 04-17-2013, 07:07 PM   #13
Commanderwiggin
HPF ran 16-18PSI on a stock motor, Ray's ProEFI runs 16PSI iirc, MaxPSI has recently ran 18PSI on a smaller 6266 turbo...14 is no big deal.
Old 04-17-2013, 08:23 PM   #14
LilFlip#2
Hey Guys
Thanks for the input. As far as my boost I am seeing 11lbs at 8000 rpm according to my AEM gauge, my afr at idle is 14.7 -/+ and my vacum on idle is -20.
Car runs great besides the AFR concern. I did turn down the Methanol controller to start @ 2 PSI vs 3 PSI. I will do some more runs.
I used a program called BMWLogger to clear my adaptations but think I might need a INPA to really clear it.
This AA kit is suppose to make 11-12 lbs of boost. I am always running 91 Craptane in Cali.
Old 04-17-2013, 09:05 PM   #15
TrippinBimmer
My Ride: Just Fast!
Originally Posted by LilFlip#2 View Post
Hey Guys
Does ur AFR gauge do at WOT? I know that if u take AFR from tailpipe its about 1 point higher then what it really is at the headers....
Alpine White M3
MaximumPSI Stage4
Old 04-17-2013, 09:38 PM   #16
LilFlip#2
My afr gauge shows between high 11's to high 12's. it happens so fast that I really can't see it.
Does it make a difference if I am catless ?
Old 04-17-2013, 09:42 PM   #17
LilFlip#2
 photo 11DB7CB5-2872-4740-9D3B-01452497D191-1040-000000F8E7444164_zps6c86b4a4.jpg
Old 04-17-2013, 10:55 PM   #18
AMG-ETR
Do you have a GoPro? Use the suction mount on the side window and point the camera to the gauges if they are on the steering wheel.
You should be able to slow down the video after and see what your AFR's are at for each RPM.
Old 04-18-2013, 01:28 AM   #19
MSpired
But that's all on higher octane's, not 91.
Old 04-27-2013, 12:32 PM   #20
lutzperformance
Lutz Performance-FL BMW F/I
My Ride: 1995 BMW M3, 04 Z06
Send a message via AIM to lutzperformance
Any update on this, as someone stated, AFR's on the dyno due read higher than that of a Wideband in the car, but these numbers are pretty far from normal, have you contacted anyone at AA prior to these postings?
-Andrew
lutzperformance is offline   Reply With Quote
