Active Auto Generation 6 stage 2 dyno..need input - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-28-2013, 12:24 PM   #21
LilFlip#2
My Ride: not a bimmer
I have contacted AA but it seems like they are blaming the the adaptations. I cleared the adaptations again and left a message for ZAK 4 days ago and haven't heard back from him.
Originally Posted by lutzperformance View Post
Any update on this, as someone stated, AFR's on the dyno due read higher than that of a Wideband in the car, but these numbers are pretty far from normal, have you contacted anyone at AA prior to these postings?
-Andrew
2005 IB ZCP - AA 1.5 HKS - Work VSXX - 430 RWHP 91 Octane
LilFlip#2 is offline   Reply With Quote
Old 04-29-2013, 10:20 AM   #22
lutzperformance
Lutz Performance-FL BMW F/I
My Ride: 1995 BMW M3, 04 Z06
Send a message via AIM to lutzperformance
What did you use to clear adaptions? This most definitely cause an issue. Have you looked at your fuel system at all, how old is the stock in tank pump? Have you confirmed in-line pump is working without any issues as well?
lutzperformance is offline   Reply With Quote
Old 05-01-2013, 12:07 PM   #23
jonny_blaze
My Ride: E46 M3 AA HKS S/C
Did you PM or call?
Send Zak an email or call directly for a fast response...I know the guy's crazy busy. Without having a proper tool to clear adaptations it will be a HUGE variable in your situation. Also did you ensure the FPR is set up correctly (I had to play around with it a bit). Have you verify the fuel system operation as recommended by Lutz? You can do this if you tap a fitting adapter to a gauge and monitor fuel pressure under load on the dyno. You can do this if you tap a fitting adapter to a gauge and monitor fuel pressure under load on the dyno.
If all that is good, make sure your pre cat oxygen sensors are not wearing out...sometimes the car's components are the real cause other than the kit or tune (big issue on the E9X M3). Running kit's of this level require optimum readings and operation of the factory electronics as well.
Hope this helps you ! Let us know how it goes.
jonny_blaze is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-02-2013, 11:26 AM   #24
triksterut
My Ride: 05 M3 Vert
Hey all,
Zak and I just got my Gen 7 Stage 2 tuned at a local dyno - I was also concerned that it was a bit lean (my only other real tuning experience is from an MR2 turbo). Zak says this is perfect. I'm still trying to work out a few lean spots with light throttle at 2300-3200 - but Zak has been great to work with. I was just hoping for a bit more "plug and play" See below dyno:
triksterut is offline   Reply With Quote
