Sponsored by BimmerWorld
Old 04-17-2013, 08:48 PM   #1
330iBlue
My Ride: 05 330i
Control arm bushings?
Hey guys, had my oil changed at dealership. I know that is blasphemy, but it only cost $90 and I got a much needed car wash. Anyway, they said both CR bushings are worn out and should be replaced. My question is, should I just replace just the bushings or replace the whole arm, which i believe ,already have the bushing pressed in them?
330iBlue is offline   Reply With Quote
Old 04-17-2013, 08:59 PM   #2
jzwu
My Ride: 2005 BMW 330Cic
Just the bushings.
jzwu is offline   Reply With Quote
Old 04-17-2013, 09:03 PM   #3
noobsthename
My Ride: 2001 330i
The brackets have the bushings pressed in them... then the brackets are pressed onto the arms. You can't buy the arms with the bushings pre-pressed, you are thinking of the brackets. the brackets PN# 31126783376... get the Meyle ones.
noobsthename is offline   Reply With Quote
Old 04-17-2013, 09:04 PM   #4
Megalocnus
My Ride: 05 330i ZHP/MT
The bushings at the inner ends of the control arms are removable, the ball joints at the outer ends and in the middle are not.
Generally the bushings wear out faster than the ball joints (my old control arms went through three bushing sets). The bushings are already pressed in metal brackets that are completely separate from the control arms.
Chances are you need to replace just the bushings, but it can't hurt to test the ball joints before doing this - just in case.
Megalocnus is offline   Reply With Quote
Old 04-17-2013, 10:03 PM   #5
330iBlue
My Ride: 05 330i
Thanks guys for the clarification. Follow up question on testing the ball joints. Can you test if with out having go take it of the car? I like to order online and have it ready once I start pulling things off the car?
Old 04-17-2013, 11:01 PM   #6
haurelio
My Ride: 2001 bmw 325i
you can order from bmaparts.com, usually deliver within 2 days sometimes even next day
Contact me if you need to unlock your phone.
Also can code your car
Old 04-17-2013, 11:11 PM   #7
choxor
My Ride: JDM
choxor is online now   Reply With Quote
Old 04-18-2013, 01:17 PM   #8
Bimmerguy91
My Ride: 2010 328I M Sport
Depends on the condition of your ball joints. I just replaced my front control arms and fcab's. I used Febi parts
Bimmerguy91 is offline   Reply With Quote
Old 04-19-2013, 10:03 AM   #9
Xtiananything
My Ride: '01 330i Mtech1
I just replaced my left and right front control arm bushings yesterday. You just need the bracket with bushing in it, not the whole arm. Or if you want, just get the bushing, but popping it out and inserting the new one is kinda tough. I'd spend the $10-$20 extra for the bracket with bushing inserted already
Xtiananything is offline   Reply With Quote
Old 04-19-2013, 10:26 AM   #10
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Just replace the control ARM bushing. Check ball joints to see if they could be bad.
Use 2/3 jaw puller to remove and dishsoap to put them on.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is online now   Reply With Quote
Old 05-23-2013, 11:15 AM   #11
330iBlue
My Ride: 05 330i
I have 330i 05, do I have to remove the whole control arm from the car to install new bushings?
Old 05-23-2013, 02:51 PM   #12
BMWCaptain
No removal of ARM needed. Just pull the old one off and install the new one. Use dishsoap as a lubricant.
BMWCaptainE46.com
Old 05-23-2013, 03:00 PM   #13
Red 90
My Ride: 325i
Do a quick search on youtube for E46 bushings and there are plenty of diy videos there. It's a pretty simple procedure especially if you buy the bushing with the carrier on it.
Red 90 is offline   Reply With Quote
Old 05-24-2013, 11:37 PM   #14
kfiggins
My Ride: e46 330ci ZHP
Just replace bushings with oem
kfiggins is offline   Reply With Quote
Old 06-10-2013, 10:43 PM   #15
330iBlue
My Ride: 05 330i
Did the bushings this weekend. Hats off to the local guy at Advance Auto. He had this tool kit made to push off the bushing instead of pulling it off. This prevented my from damaging the ball joints on the arm control. The left bushing (driver) was really damaged coated to the right one. Not sure why? Any ways, no more thump when I go over bumps. Good feeling!!!
Old 06-10-2013, 11:50 PM   #16
BMWCaptain
What is the name of the tool you used?
BMWCaptainE46.com
Old 06-11-2013, 12:15 AM   #17
330iBlue
My Ride: 05 330i
Don't know the name but here is the picture of the case and here it is attached to the left arm control pulling out the inner tubing of what was left of the bushing.
ID:	510432   Click image for larger version
Old 06-11-2013, 07:40 AM   #18
BMWCaptain
Nice, thanks for the picture.
I will check with my local Advance to see if they have one.
BMWCaptainE46.com
Old 06-11-2013, 08:52 AM   #19
Astheros
My Ride: BMW
Re: Control arm bushings?
Guys...I am about to do this 2. Are the polyurethane bushings worth it? And is 125$ for labor a good price? I dont have a garage so diy is hard for me.
Evil men will triumph so long as good men stand by and do nothing.
Astheros is offline   Reply With Quote
Old 06-11-2013, 12:31 PM   #20
330iBlue
My Ride: 05 330i
Not sure about the poly. I got the Meyle HD bushings that came already pressed in the metal bracket. If you have to press them yourself, get the Meyle. Too bad about not having garage, but $125 to install, I think is far. I got my bushings at BMA auto. They good price and usually free shipping. Here is a picture of the old one and the new Meyle. This is the front driver side bushing. It was far worse then the passenger side.
