Sponsored by BimmerWorld
Old 04-18-2013, 10:09 AM   #1
flexer7
My Ride: 2001CabrioTiTASilver
brake pad sensor light remain on.....
I replaced the front brakes a year ago and instead of replacing the pad-wear sensor, I cut the sensor off and tied the two wires together, reset brake light - lights out - it works....
Now a year later same process for the rear, replaced pads, cut sensor off, tied the two wires together, reset the brake light - it goes off, but only to come back a few minutes later. I've made sure both the wires are tied together tightly. I can get the light to go off when i re-set it, but it comes back on shortly afterwards.
Any idea what's happening? Can I not trick both front and back sensors bt tie the wires together?
Please advise.
FLEX
flexer7 is offline   Reply With Quote
Old 04-18-2013, 11:45 AM   #2
My Ride: Lexus
just buy new aftermarket sensors. the wires are so frail and thin that the slightest break will trip the light. been there done that.
