E46 Xi Forum
Old 04-18-2013, 08:48 PM   #21
E46BAV91
My Ride: 325xi wagon
Nah I'm a closet wanna be grease monkey. That isn't a picture anyone needs to see lol
E46BAV91 is offline   Reply With Quote
Old 04-18-2013, 09:42 PM   #22
e46alfonso
My Ride: 330xi MT, mustang gt
Old 04-23-2013, 01:47 PM   #23
E46BAV90
My Ride: 330ci & 325xi
I don't know if she'll want me to put a picture of her in this shark tank...
2002 330ci & 1987 325i vert
SIG PIC
Clutch Slave Cylinder Replacement DIY
E46BAV90 is offline   Reply With Quote
Old 04-23-2013, 02:15 PM   #24
SamDoe1
My Ride: 4cyl of fury
Originally Posted by e46alfonso View Post
bosch coils are only $25 each.
Take a picture of the fiance replacing the coil and post it here.
Fixed.
Coil replacement is super easy. If you look through the DIY section for a tutorial on how to replace the valve cover gasket or spark plugs on a non-M engine, it tells you how to remove and replace the coils.
Old 04-23-2013, 02:23 PM   #25
E46BAV90
Originally Posted by SamDoe1 View Post
Fixed.
Gracias
SIG PIC
Old 04-26-2013, 12:15 PM   #26
E46BAV91
2003 325XI 4th cylinder misfire
Coil was replaced. Car ran beautifully for about two days and now it's doing the same shake and pulling the same code. Any thoughts? Click image for larger version
Old 04-26-2013, 12:35 PM   #27
SamDoe1
Originally Posted by E46BAV91 View Post
Coil was replaced. Car ran beautifully for about two days and now it's doing the same shake and pulling the same code. Any thoughts? Attachment 502545
Post the code.
Swap the coil to a different cylinder and see what happens.
Old 04-26-2013, 12:43 PM   #28
E46BAV91
Code is posted twice. P1349.
Old 04-26-2013, 03:16 PM   #29
SamDoe1
Swap the coil with another and see if the misfire follows.
Old 04-26-2013, 03:20 PM   #30
e46alfonso
What coil brand did you use?
I'd do a compression test before doing anything else. Exhaust valves go bad sometimes.
If compression checks out fine then it has be a clogged injector.
