Weird noises when turning left/right - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 04-18-2013, 02:43 PM   #1
BMWSauberF1.09
My Ride: 2002 325i Sedan
Question Weird noises when turning left/right
For the past two weeks I have had a weird clicking noise coming from the front when I turn the steering wheel left and right. This happens when stopped and while driving at low speeds. There is also the same noise that happens when reversing. During full lock in either direction there is a loud grinding noise as if scraping the chassis on a speed bump. Once in a while there is a loud POP when I'm at full lock. I am on KW V1 coilovers and Cosmo racing camber plates. (both professionally installed). I have also checked the power steering fluid and it is at the required amount.
I have searched the forum and could not find a situation like mine. If there is one please link it to avoid wasting everyones time!
Thank you in advance!
BMWSauberF1.09 is offline   Reply With Quote
Old 04-19-2013, 08:30 AM   #2
BMWSauberF1.09
bump
Old 04-19-2013, 09:15 AM   #3
GSherbs
My Ride: 2002 330 xi
You searched and can't find anything about clicking noises coming from the front while turning?
Really?
Maybe I'm missing something in your explanation but it sounds like any of a number of things that come up in the forum all the time. Wheel bearings, CVs, FCABs, sway bar links - have you eliminated any of these already?
GSherbs is offline   Reply With Quote
Old 04-19-2013, 09:17 AM   #4
03BIMMERM3
My Ride: 2003 BMW M3
Are you sure your not rubbing, depending on how low your are...Have you replaced your FCABs recently?
Sent from my myTouch_4G_Slide using Bimmer App
03BIMMERM3 is offline   Reply With Quote
Old 04-19-2013, 12:32 PM   #5
BMWSauberF1.09
Really?
I have replaced the FCAB approximately 15k km ago, the sway bar links are brand new approx ~100 km. The wheel bearing looks good.
I raised the car to almost stock height to see if it was rubbing that was causing the noise and even at that height it was still making the same noises.
Also when I make turns the steering wheel does not have the same response and kick back as it did before. Its almost as if there is no power steering.
Old 04-19-2013, 06:24 PM   #6
03BIMMERM3
Id check out the tie rods, as for the steering wheel, id check your power steering fluid level again..make sure theres no leaks
