Sponsored by BimmerWorld
Old 04-19-2013, 11:07 AM   #1
Caden
My Ride: 2012 Genesis 5.0
Brakes squealing when new...
So I recently replaced my front pads and rotors and my rear pads. The rear doesn't make a noise, the fronts are loud. Rotors are Bosch and pads are Wagner ThermoQuiet. I bedded them in correctly, what could be the issue?
Current: 2015 Hyundai Genesis 3.8 Ultimate
Wife's: 2008 BMW 535i
Preivous BMWs: 1988 325is, 2001 325i, 2001 330ci vert, 2006 325i.
Others of note: 2012 Genesis 5.0, 2011 Audi S4 APR Stage II.
Caden is offline   Reply With Quote
Old 04-19-2013, 12:35 PM   #2
My Ride: 2016 Lexus
not using quality brakes
Old 04-20-2013, 06:24 PM   #3
Caden
I thought they were quality? What would you recommend? Akebano Euros?
Old 04-24-2013, 07:34 PM   #4
Weste46
My Ride: 2001 330ci
Did you use brake compound for the backs of the pads? If not, take them off and use some OEM brake compound on all the backs, and clean up and grease guider pins with the same compound while you're at it.
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 04-24-2013, 07:42 PM   #5
Weste46
My Ride: 2001 330ci
...but yeah I put on Akebono ceramic pads with Meyle Platinum rotors on all 4 corners, make less noise than OE. (not squeaking noise, just braking noise, didn't know I had any till I switched!)
