Sponsored by BimmerWorld
Old 04-19-2013, 11:39 AM   #1
PolishBMW21
My Ride: 2002 325i
Question Knockin/clunking comming from coilovers
Recently installed raceland coilovers (I am aware that you get what you pay for)
I currently have them bottomed out, when I turn the wheel past a certain point at low speeds, or even while parked I hear a knocking/clunking type of noise comming from inside the fender. I was wondering if anyone else has had this problems and if so what can I do to fix it. Please let me know if you have any ideas
P.s. if your just gunna tell me that racelands are ****, then save yourself the trouble because ive heard it b4.
Thanks in advance for any help!!
PolishBMW21 is offline   Reply With Quote
Old 04-20-2013, 01:33 AM   #2
jamex
My Ride: 2005 325Ci
Most likely your swaybar endlinks. If you re-used your stock endlinks and you're slammed, they're too long and they're buckling when you turn. Get adjustables or search this forum for an alternative endlink....there are a couple of other vehicle (non-bmw) whose stock endlink size are a good enough fit.
jamex is offline   Reply With Quote
Old 04-20-2013, 01:53 AM   #3
sjacoby112
My Ride: 2002 325ci
if they're ultimos they would have came with shorter end links. so if that's the case it might be your wheel hitting the strut. a lot of people put 5mm spacers on to clear it. that's what I have
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 04-22-2013, 09:53 AM   #4
PolishBMW21
My Ride: 2002 325i
When i have the hood open, you can see the coil spin the jerk back into place. Could the spring not be seated correctly, or could it be something else?
Old 11-09-2013, 06:10 PM   #5
drese46
My Ride: bmw e46 330ci
Hey bro I was trying to get a hold of u I'm the guy that works at chipotle witb the black e46 I want to get a exhaust and was wondering were u got urs
drese46 is offline   Reply With Quote
