Old 04-19-2013, 10:58 AM   #1
The last emperor
My Ride: 03 BMW e46
Need new oil pan
Where is the best place to find one? Looking on eBay they go for about $300-$500. Any idea of where I can find them for cheaper?
Respect all, Fear none
The last emperor is offline   Reply With Quote
Old 04-19-2013, 01:30 PM   #2
01e46325
My Ride: BMW 325Ci
I have one without the sensor. Let me know if you're interested
01e46325 is offline   Reply With Quote
Old 04-19-2013, 02:05 PM   #3
My Ride: Lexus
what happened to yours
Old 04-19-2013, 04:14 PM   #4
The last emperor
My Ride: 03 BMW e46
Need new oil pan
Oil pan plug stripped, is there an easier fix?
Old 04-19-2013, 04:23 PM   #5
My Ride: Lexus
cross thread or over tighten?
Old 04-19-2013, 04:46 PM   #6
sunsetcoast
My Ride: '99 323i & '00 323iT
To change oil? Mighty-Vac, etc.
sunsetcoast is offline   Reply With Quote
Old 04-19-2013, 05:22 PM   #7
The last emperor
My Ride: 03 BMW e46
Need new oil pan
I changed my oil today. Yeah part of the cross thread came out, idk how that's possible but we were able to tighten the plug, I'm sure it will get loosen soon
Old 04-19-2013, 05:22 PM   #8
Grande D
My Ride: E36 M3
I see 10 on eBay for $180 shipped.
It will change your life!
Old 04-20-2013, 01:24 AM   #9
CirrusSR22
My Ride: E36 318ti, E46 323it
I bought a car with bad threads. I used a new sealing ring, got it torqued and never touched it again. Bought an oil extractor and I'll never go back! 9 years later I finally did a proper Time Sert fix when I pulled the pan to change the pan gasket. I still use the extractor though, even though the drain threads are fixed.
CirrusSR22 is offline   Reply With Quote
Old 10-21-2013, 04:37 PM   #10
The last emperor
My Ride: 03 BMW e46
Re: Need new oil pan
You still have it?
Sent from my LG-D801 using BimmerApp mobile app
Old 11-20-2013, 10:20 AM   #11
The last emperor
My Ride: 03 BMW e46
Bump
Still looking for one, anybody has one for sale?
Old 11-20-2013, 10:40 AM   #12
bimmernate
My Ride: 2003 330i ZHP
The pan or the bolt? The bolts are designed to snap off before you strip the pan. Check if there is still a piece of the bolt in the hole, the bolt is hollow so you can back it out.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 11-20-2013, 11:16 AM   #13
The last emperor
My Ride: 03 BMW e46
I need the oil pan, the threads are bad and i wanna replace it
Old 11-20-2013, 11:30 AM   #14
Zell
Zell's Avatar
My Ride: so turbo wow
You can easily fix that. No need for an entire oil pan. Just Time Sert it (M12 x 1.5) and fix the threads. Much cheaper and less laborious than the whole oil pan. That requires a looooot of work.
http://www.amazon.com/TIME-SERT-Metr.../dp/B001JK44D4
Also a good reason to consider an oil extractor - then you won't need to touch the oil drain plug. Much, much easier and less messy.
Old 11-20-2013, 12:07 PM   #15
The last emperor
My Ride: 03 BMW e46
Thanks zell, that sounds like a great idea i will look into that thanks.
Old 11-20-2013, 12:21 PM   #16
WDE46
My Ride: '13 128i, '04 330Ci
+1 on doing time serts.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 11-20-2013, 01:31 PM   #17
FenderGuy05
My Ride: 2002 BMW 325i
Not trying to hijack, but I'm actually considering this route as well, any recommendations on what extractor to go with? I may actually be able to change the oil in my apartment garage if I do this.
FenderGuy05 is offline   Reply With Quote
Old 11-20-2013, 01:48 PM   #18
SoCaLe39
My Ride: 06 M5 & 03 325i
Here's a solution some the M5 guys are using:
http://www.fumotousa.com/
SoCaLe39 is offline   Reply With Quote
Old 11-20-2013, 02:03 PM   #19
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Sounds like your pan is a prime candidate for a time-cert. They are fairly easy to install, and then you don't have to worry about that bolt backing out on you due to being loose.
The Motive Power Extractor (LINK) is what I use, just a couple pumps to bring the pressure up then walk away. Now it only holds 6 quarts so often you'll need to pause part way in a drain to dump the tank, not a big deal but just a heads up.
Fumotos (LINK) are a great option if you don't want to do a top side oil change.
-James
Old 11-20-2013, 02:48 PM   #20
Teddy7
My Ride: slides
I'm not positive that b30s and b25s share the same oil pans, but I think they do. If the timesert option doesn't end up working out let me know. I've got an oil pan from an m54b25 that I can sell you.
Teddy7 is offline   Reply With Quote
