Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-19-2013, 02:36 PM   #1
Bmwdad
My Ride: 2003 M3
Garage flooring in basement?
Just had to rip up my basement floor last night. Got some water, not much but enough to ruin laminate flooring. Hoping to solve why I got water but I don't want to have to do this again. Was thinking of putting in some kind of rubber flooring. Maybe something similar to the garage flooring type. Any thoughts or suggestions. If it happens again i want to be able to take it up dry everything out and put it back.
Bmwdad is offline   Reply With Quote
Old 04-19-2013, 03:04 PM   #2
Guest100615
Account closed per your request
You need to figure out why your basement leaked and fix it or it will happen again. If it does leak and you have the plastic garage floor type you are likely to breed mold.
Guest100615 is offline   Reply With Quote
Old 04-19-2013, 03:18 PM   #3
Bmwdad
My Ride: 2003 M3
Sadly I thought the problem was fixed. Making an apt with a basement waterproofer to solve this. I'm more interested if that type of flooring would look ok and hold up. We had a huge rain storm over the past week. People who haven't had water in 30 yrs had water damage. This is the second laminate floor I've laid and torn up.
Old 04-20-2013, 06:38 AM   #4
Guest100615
I had the same situation with my old house.......it had not leaked in 20 years either and then we had 6 inches of rain in 6 hours....it was rough.
You need to make sure all the water drains away from the outside. Gutters and even a small trench in the grass.
I cut out a trench in my basement that went through all the rooms and dug out the dirt beneath and emplace some black pipe with holes in it and ran a sock over it. Buried it in the dirt and put new concrete over top.
Then I ran it to the sump pump and ran a new drain up the wall and out the side of the house. I dug a trench in the yard with pvc pipe and sloped it to the sewer line for water runoff.
No more problems ! You have to fix it from the outside. The 'waterproofing' paint (drylok) does not work. It seals the pores, but does not prevent water from coming through. It is going to take more than a small layer of paint to hold back mother nature.
Unless the water issue is solved, I don't think it matters what kind of flooring you put in. Water will wick up from the floor, if the ground is saturated. Any moisture that enters can potentially remain under the flooring, rot the floor or breed mold and you won't be aware until it is too late.
You might also want to consider replacing your sump pump if it is old. They all seem to fail at the same time.......ask me how I know. Just buy one and keep it in the house or replace the old one with the new and keep the old one as a reserve.
Old 04-20-2013, 06:52 AM   #5
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
I am very happy with my gladiator floor tiles.
They are hard plastic, but sort of flexible, to give you a slight "cushion" effect.
They are not cheap, but look great and never seem to get dirty.
JMO.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 06-12-2013, 10:47 PM   #6
borinka99
My Ride: G35 Coupe
Send a message via AIM to borinka99
JMO.
Do these need any kind of prep? Or do you just snap them in and they stay still?
G35 Coupe
borinka99 is offline   Reply With Quote
Old 06-13-2013, 12:28 AM   #7
GlockMan
GlockMan's Avatar
Zero prep. They dont move (wall to wall)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 06-13-2013, 12:55 AM   #8
borinka99
My Ride: G35 Coupe
cool, thanks
G35 Coupe
Old 06-19-2013, 11:30 PM   #9
zbeam3
My Ride: VQ35
Acid stain the concrete and top coat.
zbeam3 is offline   Reply With Quote
