///M3 Forum
Old 04-20-2013, 07:46 AM   #1
Rka
My Ride: M3 SMG-03
UCC M5 Hybrid clutch problem
I am about to install a M5 hybrid clutch LTW stg 2, on my car ( M3 E46 SMG)
The workshops have problem with that the clutch snatches when driving slowly from standstill. Could this be a matter of break in ?
The workshop is also not satisfied how the car change gears..
They will run a new "learning process" on the SMG. I hope they slove the problem.
Any input would be great.
/Erik
Rka is offline   Reply With Quote
Old 04-20-2013, 11:49 AM   #2
wilsel
My Ride: 05 AW M3 ZCP
Is the M5 SMG tranny the same as ours? Surely the flywheel isn't. I've never heard of this being done before.
wilsel is offline   Reply With Quote
Old 04-20-2013, 01:13 PM   #3
$ilent ///M
My Ride: 03.5 M3 smg lsb
did they reset the characteristic curve and relearn the clutch slip points. these are the 2 service functions required after clutch replacement
$ilent ///M is offline   Reply With Quote
Old 04-20-2013, 01:15 PM   #4
Rka
My Ride: M3 SMG-03
It´s a rebulid clutch from a S38 (M5)
http://store.uucmotorwerks.com/ltw-s...luid-p248.aspx
Old 04-20-2013, 02:08 PM   #5
Rka
My Ride: M3 SMG-03
Thanks for the input. I think they've done what should be done with a OEM clutch replacement. But I'll check with them on Monday.
Old 04-25-2013, 03:10 PM   #6
Rka
My Ride: M3 SMG-03
Picked up the car today. The clutch is working properly, after a new learning.
No doubt this is race stuff
Old 05-02-2013, 06:41 PM   #7
illestminimike
My Ride: Project Drama
Glad it worked out for you.
Old 05-05-2013, 11:33 PM   #8
Sinful7
Banned User
My Ride: e46 m3
when my smg clutch went i really considered doing this swap, but considering im just a stock m3, i went to a stock clutch.. but belive me i really considered this upgrade for when i go FI, if i ever do lol..
Sinful7 is offline   Reply With Quote
Old 06-23-2013, 05:02 PM   #9
Rka
My Ride: M3 SMG-03
Update:Have driven the car a few trackdays and stuff works really well on the track. Gear lash noise is quite evident, and the flywheel makes it snatches when driving slowly = race stuff.
Have not changed the oil UUC sent with the kit. It is possible that much of the sound disappears with new oil.
