Old 04-20-2013, 04:11 PM   #1
nl318
My Ride: 318i 2000
Power steering hose clamp, how to tighten?
Tomorrow I'm going to flush and replace my power steering reservoir, but I cannot figure out how to tighten this new clamp. Probably it's really simple, but could somebody please tell me how to tighten this thing?
http://www.ecstuning.com/Search/32416751127/ES54907/
They look like Oetiker clamps, which I know how to tighten, but here I don't know where to crimp them.
Ps: sorry for the double post in the DIY section, I wanna change it tomorrow, and there i did not get a lot of replies.
nl318 is offline   Reply With Quote
Old 04-20-2013, 04:16 PM   #2
E46@46
My Ride: 2003 325xiT
Just buy a normal hose clamp from the hardware store and ditch that thing...
E46@46 is offline   Reply With Quote
Old 04-20-2013, 04:17 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I would use hose clamps instead of that that can be found at any autoparts store or home depot.
Old 04-20-2013, 04:34 PM   #4
2003 325i
My Ride: '03 Orient Blue 325i
Correct. That's a crimped hose clamp, one time use only.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 04-20-2013, 04:44 PM   #5
nl318
My Ride: 318i 2000
Yea, only problem is I already have them new, and shops are closed tomorrow. Does anyone know how to use them anyway?
Old 04-20-2013, 04:45 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
No idea, they were a pain in the ass to take off anyways (on the brake booster vacuum line)
Old 04-20-2013, 05:08 PM   #7
2003 325i
Need special pair of CV boot clamp pliers.
Here is a very cheap version; http://www.amazon.com/Lisle-30800-Bo...=pd_sbs_auto_3
#askamechanic
Old 04-20-2013, 05:14 PM   #8
nl318
My Ride: 318i 2000
Ahh thats a shame! Some blunt pincers wont work on this one? Although i have no idea where to place it.
Old 04-20-2013, 05:21 PM   #9
2003 325i
they might. Around the bulge at 7 o'clock in the clamp pic. That's assuming the bulge at 9 o'clock is pressed together and won't just open up on you. I'm not a big fan of that clamp, like others have said I'd put on a gear clamp and call it a day.
Old 04-20-2013, 05:32 PM   #10
nl318
My Ride: 318i 2000
Hmm, actually the one at 7 o'clock separates from the ring, this is what confuses me. Shame they didn't give me those other clamps at the dealer.
Old 04-20-2013, 05:46 PM   #11
dslboomer
My Ride: 2001 BMW 330I
You need to squeeze the neck of the Oetiker clamp like this with the kinpex pliers. A ceramic tile nipper works too.
[Edit] This is wrong way. I was doing for a used clamp where the looped part is pulled apart from the first install.
See post #19 for the right way.
dslboomer is offline   Reply With Quote
Old 04-20-2013, 05:55 PM   #12
nl318
My Ride: 318i 2000
Thanks for the picture! But how exactly does this tighten them? As both points already touch each other.
Old 04-20-2013, 06:04 PM   #13
dslboomer
Neck should not be touching when pre-installed on the hose.
If it is touching, you can not use it obviously.
That's why it is one time use only even though I reused a few times for low pressure applications. You may bend to make a larger loop for that neck area in a pinch.
Old 04-20-2013, 06:07 PM   #14
jdstrickland
My Ride: '94 325iC & '00 323i
That clamp takes a special tool to crimp it. If you can get a regular hose clamp that is tightened with a 7mm or 8mm (the smaller one is better here) driver, then you are home free. You need either a regular hose clamp or a special tool.
Having said that, I replaced a power steering hose on my daughter's '00 323, and I don't remember that there was a hose clamp at all. I forget lots of stuff though...
Old 04-20-2013, 06:08 PM   #15
nl318
My Ride: 318i 2000
Ah! The new ones I have look exactly like the picture. So first I need to bend the neck, put them on the hose and tighten?
Old 04-20-2013, 06:16 PM   #16
hanna
My Ride: BMW 328i
Oetiker clamp is the way to go. It provides the even 360 prifessional compression, prevents leaks
hanna is offline   Reply With Quote
Old 04-20-2013, 06:17 PM   #17
dslboomer
I bet it will spread out once pre-installed on to the hose.
Old 04-20-2013, 06:23 PM   #18
nl318
My Ride: 318i 2000
Thanks a lot! Hope it will I'm gonna try tomorrow.
Old 04-20-2013, 07:44 PM   #19
jdstrickland
I think the clamp location is not what was shown. Squeeze the clamp in this pic to make it tight...
Old 04-20-2013, 07:45 PM   #20
jdstrickland
OR, you can use a clamp that has a screw to make it tight.
