Sponsored by BAVSOUND
Old 04-21-2013, 02:35 AM   #1
Bez9001
My Ride: 2003 E46 325 coupe
Eonon d5113e installed
I have just bought a D5113e and fitted it myself (I watched a lot of you tube videos first on how to fit it) It looks great and was easy to install.
My heating vent was a bit if a bitch but apart from that smooth install.
I left the gps aerial under the dash board to the side of the heating vent it picks up a great signal.
The radio is a bit basic for tuning etc but works just fine.
I have no need for the DVD function but a good gimmick.
The sygic sat nav is great with full uk postcodes,
The Bluetooth works great too.
However you need to leave sat nav screen when a phone call comes in.
Is their away of using Bluetooth phone calls at the same time as sat nav? as this is essential to me. If you are on a call and try to use nav the call cuts out. This is is a issue for me need help to fix this.
The screen has a glare big time but I can live with this.
I have the iPod lead coming out of my glove box this works great And it charges my iphone (Bonus)
I have moved my heating controls bellow. It looks great but want to buy proper relocation unit for it as it will bother me if I don't.
Bez9001 is offline   Reply With Quote
Old 05-17-2013, 06:22 PM   #2
buddyn2007
My Ride: 2001 330ci Coupe
I was able to install my eonon d5113 also to my 2001 330ci. Everything worked perfectly except that after I left from the place of the installer, my side view mirror stopped working. A day later, my signal flashers stopped working as well. Then a day after that, my airconditioner stopped cooling and my power windows no longer functioned. I brought the car to the bmw service centre and they told me that based on the computer diagnosis, the fault was in the d5113 and I had to install the old radio back.
After they installed the old radio back, the functions which stopped working in the car started working again.
Did I miss out anything during the wiring process that could have caused the problem? I used the adapters which came with it. I did not remove the battery cable during the install. I did the reset of the d5113 after the install. Did I miss any step that could have cause the fault problem during the install. Thank you!
buddyn2007 is offline   Reply With Quote
Old 06-24-2013, 12:59 PM   #3
badchuchu
My Ride: TSX
Could you post pics OP? I just bought a 2001 m3 and Im in the market for a new center console.
Well to be honest, I am primarily interested in units thatll let me charge my iphone5 and play music (digital preferred).
badchuchu is offline   Reply With Quote
